Ambient Downlight
I swapped the broken filament bulb in the rear view mirror for an amber LED. It's the perfect illumination.
However, on installing it, I soldered it onto the wires from the old bulb, rather than free the wires from the terminal block and wire the new ones in; I didn't want to risk loosing the tightness of the clip.
Anyhow, so I know that the LED and resistor are wired in just as the old filament bulb was.
However I now notice that th LED is constantly illuminated. Doesn't matter if the ignition is on, or if the car is shut off and locked, it stays illuminated.
Would I be right in remembering that the old filament bulbs only light up when the key is in?
Is it drawing off some residual current in the system? Is this a problem? It's only a tiny LED so I can't imagine it having much of an affect on the battery.
There should be no residual current in the system, certainly nothing more than a few hundreds of a second maybe. I would check the connections and make sure you're using the right size resistor.
I imagine that whatever transistor supplies the current, that the filament bulbs would also receive the same 21.5mA, except in this instance it wouldn't be sufficient to illuminate the filament. My father says I have the option of putting in another resistor across the LED, to turn it off, however it will still draw the same 22mA regardless.
However after trying a couple resistors, the bulb stayed illuminated. I found an old filament bulb, and even that when wired in stayed illuminated when the car was all shut off.
So my father thinks that the reason is perhaps one of the control modules is faulty, or whatever it is that sends current to those wires. He says perhaps the wires came into contact with one another to blow it, however I can't see how that could have been the case.
Possibly explained why the bulb blew, if it was always illuminated. Just with this CLK I have never had the bulb working. Only on my last car did it work.
However in order to prevent the LED being lit, whilst the car is turned off, you can wire a resistor in parallel. It wouldn't stop the current draw, it would still pull 21.5mA, but it wouldn't illuminate the LED. When the car is then switched on, with a much larger current it'd overcome that and illuminate the LED as required.
But the draw would still be there, and I don't know whether 21.5mA is too much continual drain on the battery for what is a nicety.
Atm I've disconnected it, but left the wires there so I'm able to solder something in if the cause is established.
Understand that most lighting circuits in your car are not "hardwired". Instead, they are controlled by electronic circuits. The ambient light int he mirror is likely switch on and off electronically via circuitry in the OCP. An LED that draws very little current may get just enough from that circuit to illuminate.
.....as for a normal bulb staying lit now....well that's another issue!
These cars get weird when some of the components are disconnected or not communicating properly. For example, I had the steering wheel off the other day and turned the car to ACC...all lights turned on, including the headlights...reconnected the steering wheel controls and airbag and so on....everything back to normal. Why they would be connected...I have no idea.
I would get an OBD tool that can connect to individual components and read codes...see if any of them is having issues...Or simply ignore the stupid light. It doesn't do anything haha.
