HORN problem
Thanks!
The best way to chase the problem is with a multimeter starting at the fuse and ending at the horn.
Does the panic button set off the horn?
If you need to check the steering wheel contacts follow the proper procedure to ensure that you don't set off the driver airbag.
The horns are easily accessible on my car with one at the right front corner and the other in the middle front. On other models they may be harder to get at.
