Does my new Front Sam need SCN
03 CLK 320 A209
Tomorrow I'll be getting my new SAM it's for my 03 w209 coupe It's the front left one that sits in front of the driver, I'm replacing it with a used one that I got off eBay and it's the same part number as the old one, question is am I going to need to take in to the dealer for Software Calibration Number "SCN"
MBworld Guru
SAMs do not need SCN coding. If the don or came form a car with the exact same options, then it's plug and play. Otherwise, you will need SDS to code the same to match your car. Note that SCN coding is usually a one-time function. It "marries" the part to the Drive Authorization System and it can't be re-coded. SAMs do not need SCN coding.
03 CLK 320 A209
MBworld Guru
It might work out of the box. I see nothing in the front SAM coding that is engine or transmission (i.e. 4MATIC) specific. I think this will be a drop-in job with no coding needed, but just in case, here are the standard settings:
Modification year: this should be OK - same MY2003 as yours
Rain/light sensor: assuming the C240 had the sensor as most did, then OK
Turning lamps: uses fog lamp as a turning lamp, probably OK whichever setting used
Mirror fold-in and fold-out feature: C240 likely did not have this, if yours does, it needs setting
Reverse gear: Probably the same - deals with gearshift linkage being physical or electronic based on facelift, since same MY2003, should be OK
'Refrigerant' pressure sensor: Again, based on facelift, so same MY2003 likely OK
03 CLK 320 A209
03 CLK 320 A209
So i finished the job around 6pm, and by today in the morning around 10am, my cars brand new battery was dead this is the 3rd battery i get i dont know how many times i can get a free replacement from advance auto parts. ive looked all over the place for a shoratage and i cant find anything. So probably not a shortage and maybe it wasnt the Sam after all, any idea of what it could be?
2005 CLK500
W209 font replacement
Please can anyone explore, what on what "exact same options" means, prior to purchasing a w209 front sam? Or instance, should, I purchase a Sam for specific year/model/body style? Example, coupe vs cabriolet, CLK 500 vs 550, 350. Etc.
respectfully
arjuna
MBworld Guru
Yes, coupe vs. cabriolet, also things like auto trunk closer , multi-contour seats, etc. If you get a SAM from a car with slightly different options, it may need to be re-coded. If you or a friend or trusted shop has SDS - then no worries. If you would rely on the dealer, then they will not touch a used SAM with a ten foot pole made form $100 bills.
2005 CLK500
Thank you, once a million. Since I haven't removed this part as yet, where can I find the part number? Would any 05 and later W209 (convertible)Sam work?
Respectfully and Appreciated
MBworld Guru
The part number is not as important as the car it comes from having the same options. Part numbers and suppliers change over the years so you can't always go by the stickers on the part itself. Post your VIN and I can give you possible part number from EPC.
2005 CLK500
2005 CLK500
*****update*****
It's been a challenge locating a front Sam for this 05 W209/CLK500 convertible.
Would it be a safe gamble to consider any W209 convertible front Sam from 05 and later?
Arjuna
Arjuna
MBworld Guru
Thanks! We had a great Thanksgiving. I cooked a turkey and it was the best yet. Our daughter and son-in-law came over and we all ate too much and then watched Christmas movies. I hope yours was good!
MY2005+ means "model year 2005 or later". There were some changes for model year 2005 that may come into play for the electronics being compatible.
2005 CLK500
Thanks for explaining my question and sharing your quality time with your loved ones.
If I may, impose few thoughts in my culture, that corolates to lives of souls, such as your and many here on the forum, that does what you all do.
Bhagwan (God), invokes degrees of his opulence into the jiva (soul)
1) knowledge
2)whealth
3)strength
4) beauty
5) popularity (Fame)
6) renunciation
The degrees of these gifts varies from soul to soul, because of our past actions (karma).
That's explains the differential us with regards to our ability towards- knowledge,whealth,health, appearance, etc
For those, whoes, degrees Excell at these gifts, needs to share with those with lower levels, which in return, will Increase their renunciation level. Where everything in their path becomes effortless and Harmonious.
Sheer Vishnu
1) knowledge
2)whealth
3)strength
4) beauty
6) renunciation
Sheer Vishnu
2005 CLK500
*******Update******
This part on eBay is from a coupe and seller stated that it will work my2005+ convertible.
Am seeking your seal of approval
Respectfully and appreciative
Arjuna
Arjuna
WWD2040452A343936
hi my w204 fuse box faulty.I need to buy correct sam .pls help with right part nember
WWD2040452A343936
2005 CLK500
Respectfully and your well wisher
Arjuna
jwb007 is offline Report Post
