FS: OEM suspension from my 2005 clk320
Hey guys, I'm selling my oem front and rear suspension from a 2005 clk320. Still in perfect working order, riding smooth and excellent when I removed them. It has everything you need except the front top mounts. Front and rear springs, Front struts minus top mounts, rear shocks. I needed to reuse the top mounts with my new coilovers. These will fit chassis code w209 which i believe are years 2003-2009 CLK's. Will also fit the w203 that is the 2001-2007 C-Class. Pick up in LA/OC area. Selling for $250. If anyone is looking to go back to stock, you need these!
Thanks,
Thanks,
Quick question, these are off a 2005 clk320 convertible. Will they fit the coupe?
Thanks!
Thanks!
I'm pretty sure coupe and convert are the same - easy to tell just by pretending you are ordering from a place like Pelican parts or whatever. They will list separate parts or they will not. But what you are overlooking is that all W209 struts and springs are not the same. The difference is not coupe v. convert, but sport vs. non-sport suspension. So you might clarify that so some person is not unhappy if they buy those. But are those original? I would think the value of 12 year old struts and shocks has got to be like $10.
ROLLNNN (05-23-2017)
I'd say at least springs should be different (convertible vs cope) because of weight difference (about 250lbs).
I got the BCracing coilovers.
