Keyless Go Issues
My keyless go didnt work, and all they did was changet he shift knob with a new button and it ready to go.
As a new car buyer...you must be willing to accept the hassle of dealing with this minor issues...dont go all dramatic on the situation.
If i wanted realaility, I would have bought something else? Oh calm down already....its just a simple problem. Even the most expensive of cars come with minor circuit boards issues and such. Likely needs a quick board change...
Start your car with the key. Then shut it off. Now see if the Keyless go works.
My Keyless Go was acting weird and using the actual real key to start the car once re initialized the whole system.
Keyless Go problems went away after that.
Try this:
I've had to use the key several times since the Keyless Go wouldn't start the car. The SA thinks there is something wrong with one of the antennas so they're going to replace that.
Then it should be simple to see what component is the problem
Can't say you didn't try.... The good news is that all the need to do is hook the DAS laptop up to your car and it will show exactly what the entire Keyless Go system is doing.
Try this, this might be your cheapest solution yet! I had similar problems like yours for a while. My local dealer decided to change the batteries in the key even though it was quite new. Problem solved. Happy camper. :p
Sorry it didn't work. But don't lose faith in MB, it's just one of those glitches that happen to the best of cars. Be glad it's surfacing now than later. Good luck!
Freakinfreak, once you get it fixed, you're gonna be so glad you did coz Keyless go is simply the BEST. Check this out, the other day I left my key in my pants pocket and threw it in the trunk after gym. The trunk lid would not stay closed coz my key was in there. Just as the doors wont lock if you have it in the cabin. Unquestionably the best option you can have.
