Mercedes Benz 2006 ML 350 4 matic
Old Jun 20, 2017 | 07:23 PM
Vipway's Avatar
2006 Ml 350 4matic
vin 4JGBB86E66A135647 Check engine come on. Mechanic say that i have to change engine...???
Old Jun 20, 2017 | 09:41 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Well, being a MY2006 CLK350, it has an M272 engine that will be in the range for potential balance shaft failure. If it has failed, there is almost never a need to change the entire engine - you'd just replace the balance shaft.
Now, just because the engine is in the range does not mean it has failed. We need the diagnstic codes and symptoms codes to know for sure.
Old Jun 21, 2017 | 05:54 AM
tw2's Avatar
tw2
Is this an ML350? What are the symptoms? Just check engine light? As Rodney said, hook it up to star and find out the codes.
Old Jun 22, 2017 | 09:42 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Oh, yeah - I see - ML350 - not CLK, but what I said still applies.
