Any advice before replacing battery - 2006 CLK 500 Convertible
Oh, and do b careful not to "stutter" the negative terminal when you disconnect and reconnect it. You will get a small spark, but it's not dangerous. If you "stutter" it and create a spray of sparks, you can damage the electronics in the car.
Looking from the top, the green arrow shows the drain from the windshield water collector, the yellow is the battery drain, and the blue is the water drain for the tray:
And from underneath (remove the fender shroud to see):
