Need Help: Soft Top does not open
I close the compartement manually.
The hydraulic oil was less than MIN.
I filled in oil, but the softtop does not start to open.
The windows open and I can hear the motor/pump, but after 2-3 seconds the action stops.
Sorry for my bad english, I am German😃
http://benzbits.com/w209/soft_top/ManualClose.wmv
If none of that helps, I would get a diagnosis with a tool that can read the soft top controller - Star Diagnosis or iCarsoft.
I have an iCarSoft Diagnose Unit i980?. It reads failure B1928.
I wonder that the motor starts to but nothing happens.
If the Switch S84/13 at the left cylinder would be defect, the motor should not start and try to open the compartment or am I wrong?
If I go to MB they will maybe change S84/13 for a lot of money because of failure B1928.
http://benzbits.com/w209/soft_top/co...t%20switch.pdf
A common problem with S84/13 is that the plastic clip that holds in place at the top of the cylinder will break. If this happens, you may be able to improvise something to hold it - like wrapping it with some wire or a tiny zip tie.
This doesent work because I can't lift the end of the top with the window.
But I sucessfully tried then to open the top automatically.
Afterwards the hydraulic oil was again under min limit and the was a lot of oil around the pump.
The left cylinder seemed to be dry (no oil).
Then I filled in again oil and sucessfully closed the top. And again there was additional oil around the pump.
Result: There is a leak and the electronic inclusively the switches are ok.
The question is now how to find the leak.
The seal was ok, but one of the two screws was not perfect tightened.
I will fill new oil beginning of next week and try if it is tight.
Does anyone know why the motor is only mounted with two screws instead of four?
