Passenger seat removal. Disconnect battery or ensure ignition is off.
Old Aug 15, 2017 | 01:01 PM
BazUK's Avatar
2004Mercedes CLK 200 K Elegance Auto. Coupe.
2004 Clk 200 K Coupe Elegance Auto. SRS Issue. Diagnostic - Occupancy Sensor.
I would like to try the following two options prior to replacing the seat sensor which will be costly.
Check the wiring & connections under the seat. This will require disconnecting plugs to the sensor and possibly others and may require the seat to be removed to inspect it properly. I was advised by one MB Garage that the battery needs disconnecting before removing the passenger seat but I've read on other forums that it is ok to disconnect all the wiring if the ignition is switched off. I would like to know if switching the ignition off is adequate or could this still cause electrical issues?
Fitting an occupancy sensor module which fools the system into thinking the seat is always occupied. I'm not sure if this will resolve my SRS fault because it is only activated when somebody is in the passenger seat. The SRS fault clears without a front passenger on the next start up. I can also bring the fault up by putting pressure on the passenger seat where the sensor is located.
Any advice on the two points above would be greatly appreciated!
Old Aug 15, 2017 | 08:35 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Switching off the ignition is sufficient.
Old Aug 15, 2017 | 09:21 PM
tw2's Avatar
tw2
Just don't put the key fob in the ignition and you are fine. I have pulled the seat out a couple of times before.
Old Aug 16, 2017 | 03:25 AM
BazUK's Avatar
First part of my query was posted a while ago but busy with other matters! Hoping to check the passenger seat wiring soon. Thanks for the reassurance. Baz
Old Aug 16, 2017 | 03:28 AM
BazUK's Avatar
Again thanks for the reassurance. Baz
Old Aug 16, 2017 | 12:46 PM
irokdastar's Avatar
2004 CLK 500
Getting to the battery is easy . I would do it just so you don't get the airbag light .
