Headlights
Old May 11, 2004 | 12:50 PM
VIZ's Avatar
VIZ
2006 Mercedes E 350 & 2008 C 300 Luxury
Headlights
Has anyone experienced problems with their Xenon headlights? I have an '03 CLK 320. The passenger side headlight has gone bad 3 times. The dealer continues to say that nothing is wrong and that there was a bad batch of Xenons and that this is not uncommon.
Old May 11, 2004 | 01:29 PM
Buck's Avatar
I'm having a similar problem. The auto level function doesn't work half the time resulting in the passenger side headlight pointing straight down. 2003 CLK 500
Old May 11, 2004 | 01:39 PM
AznxKCBoy's Avatar
2004 Mercedes Benz CLK 500
i kinda have a problem as well. the right xenon light seems to be lower than the left one. I brought my car to the dealer to have it checked out and they said nothing is wrong..
Old May 11, 2004 | 01:47 PM
calboy's Avatar
2003 CLK 320
You mean right is lower or higher? Normally the right should be higher than the left to avoid blinding oncoming traffic I think.
Old May 11, 2004 | 03:01 PM
AznxKCBoy's Avatar
ya i think its the other way around. my mistake
Old May 11, 2004 | 04:39 PM
clk2k3's Avatar
2003 CLK320, Sliver, Ash Leather, Command System, Xeon lights, K3, K4
I don't use the auto light option b/c it just doesn't work. I just manually switch on the light when I need them. As for your lights beaming lower, you can always manually adjust them. If your talking about the automatic adjustment, not sure then.
