Soft top R main cylinder burst. Clk 350
Old Feb 3, 2018 | 10:59 AM
Rilderton's Avatar
Clk 350 year 2006
Soft top R main cylinder burst after changing cluster Clk 350
I am new on this forum, so a quick Hello to all regulars. Fantastic forumand awesome advise and help to be found
My instrument cluster was replaced. When I wanted to open soft top. No go and a puddle of oil. Did a check and found Right main lift cylinder broken. ( I have attached a picture). Question I have, is this related or just bad luck? I am confident to do replacement myself, but concerned if maybe there is another issue, potentially after cluster change.
R main soft top cylinder.
Old Feb 3, 2018 | 01:44 PM
Yidney's Avatar
2008 CLK550 Cab
Not related. Frankly, I'm a bit curious why you would think it might be.
Old Feb 3, 2018 | 02:22 PM
Rilderton's Avatar
Clk 350 year 2006
Only reason I suspected was the timing of the cylinder failure. It failed first time after the cluster was replaced.
Is there anything else I should check or just replace the cylinder.
Old Feb 3, 2018 | 09:31 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Just replace the cylinder. Check with Klaus at Top Hydraulics. He won't be able to fix yours, but he may have some rebuilt spares available.
