Blue smoke
Old Feb 8, 2018 | 07:51 PM
Mercedes 28's Avatar
03 clk500
Blue smoke
I have a 03 clk500 with 1000k miles and from time to time when I start my car I get a bit of blue smoke is that something to be worried about ?
Old Feb 8, 2018 | 09:23 PM
Anker's Avatar
2009 CLK 350
It is oil smoke.
Can come from leaky valve guide seals. If its them you should also get a puff of smoke when accelerating after lifting the throttle.
Another possibility is worn rings.
A third is a failing AOS (Air Oil Separator)
Old Feb 8, 2018 | 11:43 PM
03 clk500
Thanks I'm still New to the Forum still learning how to Navigate on the forum. I hope it's not too expensive to fix. I will post updates on my progress. If it's the valve stem seals can anyone point me to Mechanic in the New York City area that's able to change them plz Greatly appreciate it
Old Feb 10, 2018 | 10:36 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You may not always get smoke when running. Both my CLK550 and SL550 will give a brief puff of oil burn like that If I start and stop them several times on a cold engine, as I might do if shuffling cars around int he driveway. When the seals are cold they shrink and will let a small amount of oil by. Once warmed up to operating temps, they seal just fine. Unless it starts getting worse and you're having to add a lot of oil between changes, I'd not worry about it.
Old Feb 11, 2018 | 02:32 PM
03 clk500
Blue smoke. To Rodney thank you for your for your feed back I Preciate it
Old Feb 11, 2018 | 05:35 PM
Anker's Avatar
2009 CLK 350
Never seen any smoke puffs from mine, My Porsche gives a good puff if it has sat for a while. :-)
Old Feb 12, 2018 | 06:08 PM
Reanimation's Avatar
270 cdi w209
Air Oil Separator/crank case breather should be the first thing to check, How many miles on the car 1,000k or 10000k or 100,000?
Old Feb 13, 2018 | 12:01 PM
03 clk500
I have 100k miles on it and I'm the second owner
