Weird climate control issue
Old Feb 20, 2018 | 07:59 PM
jspbtown's Avatar
2007 C280
2007 CLK550 cabriolet
Today when I had my climate control set at around 72 (normal) everything was fine. about 1 hour into my drive the fan would kick on, blow hot air for about 5 seconds, and then stop. It would go a couple of minutes and then do the same thing. Blow hot air at a high fan speed for a few seconds and then shut off. A few minutes later...the same thing.
I shut the climate control totally off and it still did it.
Thoughts?
Old Feb 20, 2018 | 10:34 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
So even with the ACC shut off, your blower fan was operating at various speeds? It may be a bad ACC panel, or it could be the blower motor regulator is bad. Hopefully there are stored ocees in the ACC that can be read with an appropriate tool (SDS, iCarsoft, etc.).
Old Feb 23, 2018 | 12:22 PM
04CLK5.4's Avatar
2004 CLK55 AMG
Having the same issue right now - I’ll be keeping an eye on this thread. If you look at my threads, I’m asking the same question. I’m going to post it in the tech talk section and see if we get any bites.
Old Mar 2, 2018 | 01:50 PM
04CLK5.4's Avatar
2004 CLK55 AMG
Any updates for you?
Old Mar 26, 2018 | 06:44 PM
04CLK5.4's Avatar
2004 CLK55 AMG
Checking one more time.
