downgrade 722.9 to 722.6
Old May 7, 2018 | 01:52 PM
Dsimp's Avatar
Clk 500
Angry downgrade 722.9 to 722.6
i have several issues on my Clk 350, codes for balance shaft issues, bank 1 retarded, bank 0 advanced, (110k) but not the issue for now,
in addition to the p2767, speed turbine sensor error.
it is now where it will throw the code as fast as you can reset it (ANY INFORMATION on this is MORE than welcome)is there anyway to swap this buggy 722.9 for a 722.6 (and match the ECU) ? or does this car simply have TRADE ME IN written on the back of it ?
d
Old May 7, 2018 | 11:17 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Just get the conductor plate replaced. You'll probably spend around $1400 for this dealer-only job, but it will be a permanent fix for that issue. But if you also have balance shaft troubles, ythat needs to be fixed, too, and will cost you well over $4K at the dealer. I'd look at a good indy shop for that
