Well...I thought it was a CPS.
Can someone tell me what the normal operating temp is? My gauge says 1 bar under 100C (gauge go 40-80-120C). My OBD2 scanner (which I have been leaving plugged in) has it going to about 216F when sitting at idle after driving it for a while. Normal cruising has it right around 200F
THEN.....drove it 1 hour. Parked it for about 20 minutes and went to start it and no start. Jumped out. Popped the hood. Grabbed a rag and checked the shrader valve for fuel (yes...I know...not as good as a gauge) and there was plenty of high pressure fuel spray with the key in the "run" position. Put the front engine cover piece on and poured a bottle of cold water on the ecu….and....it started right up. Time from no start with hood open, through checking the shrader valve, to pouring water was maybe 5 minutes.
The drove the car about 45 minutes and let it sit for about 3 hours. Came out and tried to start.....no start. Poured 1/2 bottle of cold water on the ecu and it started right up. Time from no start to hood open and water on...about 1 minute.
I think I have an ecu problem. Any dissenters?
Anyone have any suggestions on the repair? I have done a shallow dive and see ecu rebuilders. New ecm through Mercedes is crazy money.
I used CarComputerRepair (they are in Cary, NC) for my ecu. I wanted to retain the tune and not have it reflashed based on the VIN or to go to a stock replacement flashed per the VIN. It cost me $600. Someone else on the forum used a seller on ebay and seemed pleased with their service. The one I considered from ebay would refund your money if they could not repair it and they had a 2-3 day turnaround. And I think the cost was in the $300 range.
If my ecu was not tuned, I would have tried the no repair/no cost (except handling cost), and went with an exchange if no repair/no cost option did not work.
So is that ECU located under the hood?
Last edited by exhaustgases; Jul 9, 2018 at 03:38 PM. Reason: I had (it) instead of is.
exhaustgases...thank you as well. The MB part was about $20 more than the local parts store and it was in stock so I just went with that. And yes...the ECU is mounted on top of the engine and is visible through a cut out in the engine cover.
Pouring cool water on the ECU results in an instant ability to start.
https://xemodex.com/us/product/me9-7...-m273-engines/
Thoughts?
And that brings up another thought for the OP: Check the engine cover, especially the front section, to make sure it's properly in place and also that the insulation on the underside of it is not "drooping" and blocking airflow.
The insulation on the underside is slightly sagging off the hood but I placed a ball of tape on top of the ECU and closed the hood and it did not stick to the insulation nor did it compress so the insulation is several inches about the ecm.
A little update from today:
Drove 1 hour to work in 80 degrees. Parked it in a covered garage for 8 hours came out and it fired right up.
Drove home 1 hour in 90 degree heat and popped the hood and went inside for about 1 hour. Came out and it fired right up.
Drove about 15 minutes to the hardware store and shopped for about 10 minutes...came out and a no start. Pour 1/2 bottle of room temp water on ECU and it fired right up.
Drove 5 minutes down the street to the autoparts store. Shopped for 10 minutes. Came out and it reluctantly started and then stalled as I was backing it up. It immediately refired and drove fine. No CEL.
Drove about 45 minutes. Parked car with hood up. Came out about 3 hours later and it fired right up.
"The board, likely, had some circuit damage caused likely by capacitor failing which caused the processor to get too hot.
So I am relatively hopeful this will be a cure to my issue.
As a side note...in about a week of driving the car, while I was arranging alternative transportation, I probably had 7-10 crank but no start events. Each and every time....without fail, by pouring less than a half a bottle of water on the ecu it would immediately start. Without fail.
). Easy plug in and the car started right up and drove fine (other than some moans and groans for sitting for 5 days). Tomorrow will be the first challenge......does it start after driving 1 hour and sitting 2-3???It damn well better!
Oh...and Todd over at Pressertech has been first rate. Since the USPS screwed up they are refunding the overnight shipping so Todd is handling that for me. Nice guy....if everything works its 5 stars.
fuel pump
sending unit
cam shaft sensors, crank shaft sensors
cam shaft magnets,
MAF sensor,
canister vent valve,
purge valve
spark plugs,
all 6 coil packs.
And I still haven’t solved the issue, I’m thinking it’s the starter. My battery is only a year old. I’ve also heard it could be the coolant temp sensor but mines seems to read fine. I have no check engine light. Car runs great and doesn’t stall.
