Transmission fluid
Old Oct 10, 2018 | 08:41 AM
pvitoria's Avatar
CLS 320 CDI W219
Transmission fluid
Hi guys i can t find the right answer for what fluid and quantity to use to change my manual 6 speed gearbox fluid. WIS days MB 345 AND 0.5 lts but i read somewhere that it os 1.2 lts
Old Oct 10, 2018 | 10:21 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
All I see in WIS is 345.0:
https://bevo.mercedes-benz.com/bevolisten/345.0_en.html
Old Oct 10, 2018 | 10:44 AM
pvitoria's Avatar
CLS 320 CDI W219
Tks Rudeney that is what i found too i m going for Febi Bilstein 21647 oem A001 989 2403 i called dealer and they told me it takes 1.2 lts
Old Oct 10, 2018 | 12:12 PM
pvitoria's Avatar
CLS 320 CDI W219
Hi again oem A001 989 2403 is yellow and there is also oem A001 989 2603 thats is green what should i use the yellow one is mb 345.
Old Oct 10, 2018 | 11:56 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Either one should be The green is the Pentosin CHF 11s. It's actually a very common hydraulic fluid approved for use in many MBZ systems. I;d use whichever is less expensive or easier to obtain. Color is not important - just spec.
Old Oct 11, 2018 | 02:39 AM
pvitoria's Avatar
CLS 320 CDI W219
Tks a lot Rudeney i ll go for the yellow one with Mb 345 spec
