Coolant level
Old Oct 22, 2018 | 09:16 PM
alexandergreat's Avatar
Mercedes Benz clk550
Coolant level
Hi,
I have a (probably stupid) question:
On a clk550, the coolant expansion tank has a plastic line, that you can see by removing the cap and looking inside the tank. I understand that the coolant level must align with that line. But can it go over? Is it a minimum line or a maximum? Basically, does the coolant need to go over this line or up to this line? I couldn't find a min or max line on the tank so...
Thanks in advance.
Old Oct 22, 2018 | 11:08 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The proper coolant level is measured when cold. It should be even with the seam in the tank between the light and dark sections.
