"Hood Open" Malfunction 2004 CLK500
2004 CLK500
Has anyone experienced any issues with their hood latch sensors? My car is giving me a malfunction message saying "Hood Open" when it's most definitely secured. One of the loops that the latching mechanism attaches to has MAYBE 1mm of play, but I can't see how it would trigger any kind of sensor. The loop I'm referring to is the one on the actual hood on the driver's side. Any ideas?
I had the same issue . Turned out to be a bad switch . I just disconnected it . There are 2 bolts on the receiver . Just unbolt it and unplug the wire and the message will go away .
2004 CLK500
Was able to figure out the problem. The small arm wasn't depressing the switch when the hood closed, so I bent that arm in such a way that it would put more pressure on the switch when i closed the hood. Haven't seen the malfunction come up since.
