srs error
Old Dec 16, 2018 | 02:17 PM
jhas's Avatar
clk w209 240 petrol
srs error
hello
I am new here, my name is Jhas and I live in the Netherlands and drive a clk w209 240 of year built 2002.
I have been running for some time with this problem the srs light stays on.
I have been figuring out for some time how I can solve this problem. I get these error codes.
B1076 Fault in CAN mommunication with control unit N72/1 (upper panal control module)
B1075 CAN communication is faulty.
I can not delete the codes either, i have the icarsoft mbii.
and normally I could erase the codes but after a few times they are stuck in it
can somebody help me please?
with kind regards
Old Dec 16, 2018 | 08:41 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
jhas, please update your forum user profile to add your location a car's model year. I know you put that in your post, but if you will put it in your profile, it will appear in the left panel next to every post and will make it much easier for others to help you.
Ar you have any issues with the upper control panel" That is the panel with the "Passenger Airbag Off" light on it. If the airbag system cannot communicate with that indicator light, it will throw an error.
Old Dec 17, 2018 | 12:01 AM
jhas's Avatar
clk w209 240 petrol
Hello,
I will try it later to change the profile settings.
but no i dont have Any problems. Even the airbag yellow light go on for a few sec. And turns off if i start the car.
hazard light, Door locking Works fine.
Old Dec 17, 2018 | 10:59 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
What happens when you try to clear the codes? DO they just come right back immediately?
Old Dec 17, 2018 | 11:16 AM
jhas's Avatar
clk w209 240 petrol
Hello
the obd scanner says the code is unsuccessful erase. And the code keeps standing.
Old Dec 17, 2018 | 11:27 AM
jhas's Avatar
clk w209 240 petrol
Old Dec 17, 2018 | 11:43 AM
jhas's Avatar
clk w209 240 petrol
I need to say that the problem started when i remove the left door module (steering wheel is on the right. right drive) because my window opens out it self and the memory was everyday gone. After a few day srs light was coming and the dashboard give a few fault codes (fault in dashboard light from the big light turns everything light up) after restart the eninge its was gone and srs i erase with the scanner after a few days i cault not erase the code anymore. I tought when the jused door module come from eBay the code will erase but its still there..
I reed some where that it can be the battery. I tested it. With a volt gauge the battery is 11.70 and when i start the car it jumps to 8... volt. When the car runs it go to 13.9 volt.
(sorry for my english mine Dutch is better )
Old Dec 20, 2018 | 12:22 PM
jhas's Avatar
clk w209 240 petrol
I think i got a CAN communication problem. Can some one tell me where i need to look? New battery didnt work.
Old Dec 20, 2018 | 09:29 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I think the main problem you have is the squib in the side airbag. When it says "resistance too high" it means there is a loose connection. Since you did work in that area, it is possible you unplugged something.
Old Dec 22, 2018 | 09:42 AM
jhas's Avatar
clk w209 240 petrol
hello
today i open everthing and check the cables and for a lose connection everthing is fine. even i try to disconect the steeringwheel airbag and put the key in igniton. there come a extra fault code i put everthing back and now i got 2 fault code extra that i cant remove. ( i was just testing something) i think that the airbag module broken is(i dont hope so)
but i got a lot of CAN fault code ( i put about 4 months ago a android radio but everthing works fine till a couple of weeks)
some codes i got
B1090 --- fault in CAN communication with contol unit n70 (overhead control panel control unit). if fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check.
B1096 --- fault in CAN communication with contol unit n72/1 (upper control panae control unit). if fault code occurs with no complaint reported check.
B1030 --- control module UPC is not sending any data. if fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check.
9026 --- CAN communication is faulty
B1136 --- fault when writting the eeprom
B1129 --- fault in CAN communication with contol module command or audio
B1114 --- fault in CAN communication with contol unit OCP
Old Dec 22, 2018 | 11:06 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Are those B codes form the SRS module? If so, refer here:
http://benzbits.com/dtc/SRS%20(B%20codes).pdf
The B1090 and B1096 would indicate a bad SRS control module, but before tossing parts at the problem, I would get a proper diagnosis with SDS. While those handheld scanners are pretty good, they are not always accurate.
Old Dec 22, 2018 | 12:40 PM
jhas's Avatar
clk w209 240 petrol
The codes is not only from the srs. Tommorow i will scan again and write down with code these belong.
The dealer here have a waiting time around 2 weeks they are building a new place.
Old Dec 22, 2018 | 10:09 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You don't need a dealer for SDS! Get your own, for find an indy or skilled DIYer who has it.
Old Dec 23, 2018 | 10:51 AM
jhas's Avatar
clk w209 240 petrol
you mean a obd2 reader ?
i got this one
Amazon Amazon
Old Dec 23, 2018 | 11:35 AM
jhas's Avatar
clk w209 240 petrol
today i scan de clk i hope i write it good down
from the bottum
1 TCM - transmission control module = no DTCs
2 ESM - electronic selector = Fault in communication with vehicle ECU.
1 this vehicle is equipped with the system
2 this system is an electrical control system
3 the diagnostic connector is on
3 ECM - engine control module = No DTCs
4 ESP - electronic stability program = No DTCs
5 SRS - airbag = B1076 Fault in CAN mommunication with control unit N72/1 (upper panal control module)
B1075 CAN communication is faulty. en 2 other code that i tested with the steering wheel airbag
Clear Fault Memory : CLEAR TROUBLE CODE UNSUCCESFULLY !!
6 OCP - overhead control panal = B10DF CAN controller: CAN bus OFF
7 EIS - electronic ignition switch elcode = Fault in communication with vehicle ECU.
3 the diagnostic connector is ok
8 LCP - Lower control panel = Fault in communication with vehicle ECU.
9 UPC - upper control panel = 9026 Can communication is faulty
10 AM_F - signal acquisition and actuation... = B1030 --- control module UPC is not sending any data. if fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check.
11 REAR SAM = B1096 --- fault in CAN communication with contol unit n72/1 (upper control panae control unit). if fault code occurs with no complaint reported check.
12 RVC - rollover bar top control... = Fault in communication with vehicle ECU.
13 AHE - trailer recongnition = Fault in communication with vehicle ECU.
14 IC - instrument cluster = B1129 fault in CAN communication with control COMAND or AUDIO
15 SCM = Steering column module = No DTCs
16 PTS - Fault in communication with vehicle ECU.
17 DCM_L - door control module left = No DTCs
18 DCM_R - door control module right B120C E17/4 (right door entrance/exit lamp) : open ceruit or bulb faulty
19 RCM - rear control Module = No DTCs
20 ESA Driver - electric seat adjustment driver (with memory) = Fault in communication with vehicle ECU.
21 ESA passenger ...... Fault in communication with vehicle ECU.
22 AC Air conditioning = B1598 component m2/16 left en right defroster flaps actuator is stiff or blocked
B15A8 component m2/15 left en right flootwel flapd actuator is stiff or blocked
all codes i can delete but it comes back only the srs cant erase.
Old Dec 23, 2018 | 09:48 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
SDS = Star Diagnosis System, MBZ's computer diagnostic system. It goes beyond what an OBDII scanner can do, even those that can read MBZ's proprietary systems. It can do som tets and actuations to narrow down your problem.
Old Dec 29, 2018 | 07:31 PM
jhas's Avatar
clk w209 240 petrol
Hello Rudeney (Rodney)
i was a little bit busy with the christmas day
but i have the srs light off.
i call a frend of my he has a little business
with sellings cars and he got some obd readers (launch and delphi but the delphi borrowed) with the launch reader it was possible to erase the srs code only 1 code remain
B1072 the coding for component B48 (front passenger seat occupied and child seat recognition ) is faulty.
I checked the cables. but when I pulled out the cable with 3 wires the srs light went out, and I did not have a fault anymore (strange but true)
when he gets his delphi back i gonne check the other remaining CAN fault codes.
