W209 Command question
Old Feb 1, 2019 | 02:39 AM
Ledbelly's Avatar
2002 E240 W210 Elegance. 2003 CLK320 W209 Avantgarde.
Hello All.
I have a 2002 CLK320 which has had a command unit installed by a PO (I think, bookpack only has manual for the basic radio).
I the analogue clock on the dash is one hour fast and there is no clock setting available in the menu.
The clock settings on the command unit will only change by half an hour and will not go to GMT, just showing UK summertime.
Looking at older posts I think the problem is that the system thinks it still has the original radio so my question is, can a reset be done so that the command unit is fully integrated with the car?
The sat nav is pretty rubbish and the cd changer does not see discs so it might be worth fitting an original radio.
Any ideas?
Old Feb 1, 2019 | 10:57 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If you re-code the instrument cluster so that NAV is "not present", then you will be able to set the clock on it. This will require SDS (MBZ's Star Diagnosis). In doing so, you would lose the NAV info display in the cluster, but if you don't use the NAV, then that may be no big deal.
