ABS Light, Speedometer, Tight Steering - What do they have in common?
Old Mar 13, 2019 | 08:29 PM
Driccio62's Avatar
Clk 500
Exclamation ABS Light, Speedometer, Tight Steering - What do they have in common?
I’m new, thank you for allowing me to join. Located in Sarasota/FL. White/Black CLK500 Cabriolet.
My 2005 Clk 500 convertible had a issue develop. All at once my speedometer quit, fuel numbers went to zero, steering became tight, ABS light is on, Brake symbol for service came on and the display screen says it faulty. Check Engine light is on, Code is P0600. Less then a week ago, the valve covers were removed with new gaskets installed. Fuel line was disconnected but reattached with no issues. Mechanically the car is running fine with the exception of the heavy steering.
I appreciate any help as this problem was no existent and within a minute all these errors occurred. Brakes are fine, no work has happened at the wheels/sensors. Car has sat for several days, same problem when I restart it.
Old Mar 13, 2019 | 10:46 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Could be a voltage problem. Since the steering is heavy, maybe the power steering pump is not working well, which could be that the serpentine belt is dragging, which could also affect the alternator.
Old Mar 20, 2019 | 10:26 AM
Bmo Pete's Avatar
2024 GLE 580
Similar happened to my '05 CLK55 at 78K miles. Ultimately I needed to replace the ABS Module - ended-up buying a new one (~$1,300) after attempting a rebuild; MB sells an updated version now.
