Suggestions for upgrading sway bars/shocks struts
Can I get away with 12mm thicker and upgraded H and R sway bars and Eibach struts in the front alone, and do the back end when I can afford it?
Do you guys know the part numbers for the 12mm H and R sways and struts?
And do you recommend my approach?
I never heard of Eibach struts. I went with Bilstein struts and sachs rear shocks. I didn't want a rougher ride, I just wanted tighter cornering. Once I upgrade these parts, I'm going to replace the lower and upper control arms to tighten up the suspension a little further.
I did H&R springs (1.3 drop) on the front with new Bils on all 4 corners -
I had the thickest f/r swaybars from H&R installed
As for driving improvement I added this bar -
https://www.ebay.com/itm/MERCEDES-BE...UAAOSwt7pXL~-V
It made the biggest difference in handling -
The Mercedes tech who installed it was very impressed
with the dynamics of this bar -
The biggest thing this bar did
https://www.ebay.com/itm/Mercedes-Be...sAAOSwzPFZ3cxL
was to tighten up the rear end and reduce body flex when
turning up into a curved driveway -
Thank-You
D.B.
