M113 shaking at idle
I am having some problem with my CLK 500 MY 2005 with 7G. When idle, I can feel some vibrations inside the car. I can feel them through the car body and not through the steering wheel. No codes on SD, I have replaced all sparks and ignition coils, cleaned MAF and nothing has changed. Mechanic has checked the engine and transmission mounts (they are ok), checked the engine compression (its ok). The car has no oil leaks exept one small on oil filter. I am using Motul 5w40, I change it every year (every 5k). I tried engine flush from liquy and molly but it didnt work.
I also can hear some knocking sound in the engine on Passenger side, but I have read many threads about it.
It seems like a missfire every 2sec, but the ignition system is ok and there are no codes. Any ideas? EGR Valve? I can post a video of engine running.
Greetings
Greetings
From the above description, I would say, that you have a problem in the fuel system, probably injectors. You can try injector cleaner, in the petrol. If that don't help, have the fuel pressure checked, and if that is okay, have the injectors tested, cleaned and calibrated if necessary, or replaced.
When did you last have the fuel filter changed ?
I checked the for vacuum leaks with a smoke machine, didn’t find anything. I was disconnecting the coils one by one to find it actually swas starting to misfire when disconnected.
Also no codes, no CEL.
At first I was suspecting engine mounts, but changing the gears is smooth.
Want to check if disconnecting the MAF and putting the engine into the LIMP mode will change anything.
Can't repeat it enough. They fool even experienced professional eyes during inspection.
I've replaced mine along with several others for relatives and friends. Cars had mileage between 98k to 130k. Vibrations were 100% gone after all mounts were done. The difference was like night and day. No excessive engine movement or leaks on any of them prior to replacement. The only thing I noticed was a bit of a height difference compared to new ones. Pretty difficult to see that while it's in the car.
I changed mine only after finally a friend got in the car and asked why everything was vibrating. I got used to it over time.
All of the above is assuming everything else mentioned in this thread has been checked. I would also add a bad crankshaft pulley to the list of items that can cause vibrations on M113.
I've replaced mine along with several others for relatives and friends. Cars had mileage between 98k to 130k. Vibrations were 100% gone after all mounts were done. The difference was like night and day. No excessive engine movement or leaks on any of them prior to replacement. I replaced mine only after convincing myself for months that it was something else.
This is assuming everything else mentioned in this thread has been checked. I would also add the harmonic balancer on M113.
The vibrations you are experiencing could very well come from the faulty damper, since the missing rubber has changed the tune of the damper, that it is now out of tune with the harmonics it's supposed to dampen.
Normally, in such a case, you would expect to see the rubber torn apart, instead of the bond between rubber and steel failing. This indicated a manufacturing error.
The rust in the grove indicates that it has been going on over some time, and the alignment of the inner and outher part is still in order, so the damper has not failed yet.
I suggest you exchange it with a new MB original, not a used one from the scrap yard.
These vibrations you feel, if they come from the crankshaft, they are very harmful, increasing fatigue load and premature crankshaft failure.
Decided to roll the dice and purchased Corteco pulley, since original cost 25% of what I paid for the whole vehicle
If the Corteco HB gonna fail - it's covered with FCP euro warranty
Found it accidentally - was rinsing the cooling system and noticed something was wobbling while engine was on. Took a better look and saw this guy with a half of rubber missing.
The Tune of the new damper is critical, so you will instant feel if it's right, after you fitted it.
Some of those aftermarket parts are only close by, not exactly tuned.
To check the motor mounts, open the hood, get in the car, turn on the engine, press the brake pedal firm, and engage transmission in D
Press the throttle a bit, and you can observe the engine movement from inside the car.
The engine should not lift more than half an inch in the left side, then the this side is okay.
Now engage transmission in R and repeat. The right side should not lift more than half an inch as well.
Worn out engine mounts can let the engine lift up to 2 inch, in either side, usually the left, since it is under lift load when driving in P
