VIN Check for Balance Shaft Failure on a 2007 CLK 550 Cabriolet??
Subscribe
Jul 31, 2019 | 11:27 PM
Hi:
Ive been lurking around a bit and thought I would turn to the experts to help out. I am looking at a 2007 CLK550 V8 and want to make sure it is not in the range for potential Balance Shaft Failure (it sounds like that is a rare occurrence, but wanted to double check). I think it is outside of the range, based on the VIN but I'd like your help. The VIN # is WDBTK72FX7F222455. Any guidance on this or other things to check would be greatly appreciated.
Thank you for the assistance on this question!
Reply 0
Aug 1, 2019 | 10:52 PM
M273 engine #119528 - it's beyond the problem range.
Reply 1
Aug 2, 2019 | 12:17 AM
Thank you for the quick help!!
Reply 0
Jan 18, 2020 | 11:07 AM
vin check on this clk500
WDBTK75J75F151843 can someone do a vin check on this clk500 for a possible balance shaft problem?
Reply 0
Jan 18, 2020 | 08:20 PM
Quote: WDBTK75J75F151843 can someone do a vin check on this clk500 for a possible balance shaft problem?
You need to read more on the forums about this. You car has an M113 engine which is not affected. Only the M272/M73 engines are possibly affected by this failure.
Reply 0
Subscribe
Currently Active Users (1)
