Oil leaks a common issue?
Several of the CarFax's I have looked at on cars I have/had an interest in have had the valve cover gaskets replaced in the 40k range.
The 350 I will be checking out this afternoon shows the following: camshaft seals replaced at 38297 and valve cover gaskets at 41715. It also shows other work at 44454 including brake pads F&R. Is it safe to assume that a dealer would replace rotors at the save time? I have read around here that the rotors are soft and should not be turned. The car has cross-drilled fronts (so I assume it has the Sport Package) and I don't know, but these may be a harder materal?
All the work done while the car was under CPO warranty males the car more interesting to me, even though it is black. It currnetly has 47600 on the clock.
TIA
From CarFax:
09/30/2011 38,297 Plaza Smart Center
Creve Coeur, MO
314-301-1700
Maintenance inspection completed
Air filter replaced
Camshaft seal(s) replaced
Tire(s) balanced
Oil and filter changed
Brake fluid flushed/changed
01/25/2012 41,715 Plaza Smart Center
Creve Coeur, MO
314-301-1700
Front turn signal/parking bulb(s) replaced
Tail light bulb(s) replaced
Valve cover gasket(s) replaced
Engine timing/front cover gasket replaced
04/27/2012 44,350 Plaza Smart Center
Creve Coeur, MO
314-301-1700
Steering damper replaced
Safety inspection performed
Emissions inspection performed 05/01/2012 44,454 Dealer Inventory Vehicle offered for sale 05/02/2012 Tri-Star Mercedes
Ellisville, MO
636-458-5222
tristarmercedes.com Vehicle offered for sale
05/22/2012 Tri-Star Mercedes
Ellisville, MO
636-458-5222
tristarmercedes.com Oil and filter changed
Air filter replaced
Four wheel alignment performed
Interior trim repaired
Washed/detailed
Antifreeze/coolant flushed/changed
Two tires mounted and balanced
Front brake pads replaced
Rear brake pads replaced
Cabin air filter replaced/cleaned
Front wiper blades/refills replaced
05/22/2012 Mercedes-Benz Certified Pre-Owned Dealer
Ballwin, MO Offered for sale as a Mercedes-Benz Certified Pre-Owned Vehicle
"USA CLK350s have the M272 engine which is not known for valve cover gasket leaks like the older M112/M113 engines. It was, however, known for oil leaks from the camshaft solenoids. Also, if this is a MY2006, I'd stay away from it (search: "balance shaft") and even MY2007 'd have us check the engines serial number (via the VIN) to make sure it's not int he affected range."
Thanks for answering. It is a 2008. Well optioned. No Keyless Start or Power Trunk shut, 47500 miles. It's black over tan/capechino P3, Nav and they are asking $26900. Black is not my favorite color for cars as I am one of those who hangs their arm out the window and it get hot. Well got to get home and finish taking my 993 back to stock for an afternoon trade-in appraisal and test drive.
Craig
Seems like it leaks one side or the other, randomly, sometimes not at all.
I've gotten to kinda liking the smell of burning Mobil1 while sitting at a light. I rarely use a/c, and have driver's window open with the blower on, so the aroma wafts into the cabin. Actually overpowers my cigar aroma. Mmmm! Indy wants $400 to put new covers on. I'm dragging my feet. And I keep a fire extinguisher handy.
could this be my gasket? i drive a clk350 2006
