Location of Coolant Temperature Sensor W209
2014 Mercedes-Benz ML350 4-MATIC | 2007 CLK350
Can anyone help with a diagram, picture or description of the location of the coolant temperature sensor (assuming there's just one) on a 2007 CLK350 convertible? Thanks.
Excuse me the last message was for a clk 270.
In the mercedes doc, i don't see a coolant sensor, but the temp may be given by the Thermostat valve, located here(y110)
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/1129x584/test_55f178ba44f879b913038ad595263ae2a2cbfc31.png)
MBworld Guru
For the M272 engine, the temperature sensor on the the rear:
http://benzbits.com/m272/CoolantTempSensor.pdf
Y110 is actually the thermostat, which also has its own integrated coolant temperature sensor because it is electronically controlled.
SilverCLK280 (10-24-2022)
Thanks "Rudeney MBworld guru," I thought that was the case with regard to the sensor located on the thermostat inlet. Any information on where the coolant temperature sensor might be located? ¯\_(ツ)_/¯
