AutoTalent | Renntech Ecu Upgrade + Aero + Exhaust For Mercedes-benz CLK 63 AMG
Old Dec 16, 2019 | 01:43 PM
AutoTalent's Avatar
SPONSOR
G55
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
Click HERE to order Performance Ecu Black Series!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
Features
Long-lasting and Driver Reliability
Significant Gains in Horsepower
Increases the Performance
Significant Gains Torque
Increasing the Engine's Rev Limiter
Incredible Performance Gains
Renntech Performance Exhaust Headers
Click HERE to order Exhaust Headers!
RennTech stainless steel and ceramic-coated exhaust headers offer true bolt-on installation, mounting directly to the OE down pipes and all RennTech headers are hand built from mandrel-bent, seamless tubing and CNC machined stainless flanges. RennTech is use advanced computer aided design (CAD) and flow analysis software allows RennTech headers to deliver substantial gains across the entire RPM range. RennTech headers are constructed of the highest quality T-304 stainless steel and are ceramic coated to further reduce latent heat in the engine compartment as well as combat against thermal stress. RennTech electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that RennTech proprietary SS Exhaust Headers offers incredible performance gains and rock solid daily driver reliability.
Features
Reduce latent heat in the engine compartment
Advanced computer aided design
Stainless steel exhaust headers
Ceramic coated exhaust headers
Gains up to +11 HP; +20 LB-FT
Long-lasting and driver reliability
Increases the performance
Incredible performance gains
Renntech Performance Transmission Upgrade
Click HERE to order Performance Transmission Upgrade!
RennTech Five Speed Transmission increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. Renntech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech 722.6 Five Speed transmission upgrade consists of a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings, electrical connectors as well as a new transmission pan filter. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Improves vehicles responsiveness
Increased engine performance
High quality material used
Improved shift response
Improved performance
Greater drivability
Shift timing
Renntech Carbon Rear Mount Dtm Style Wing
Click HERE to order Rear Mount Dtm Style Wing!
RennTech full carbon fiber Aerodynamic parts for the C209 CLK is the proverbial “cherry on top” and a stunning addition to the rear of the CLK exterior. Its unique design complements the refined trunk lines yet offers a more aggressive, stand-out look. RennTech Offering aggressive styling and functional performance; our fully adjustable DTM style rear wing is designed to work in conjunction with our carbon fiber rear deck lid spoiler and improves rear down force and stability at higher speeds. The rear wing mounting piece and uprights are a single piece, manufactured from T-6061 aircraft grade aluminum and our full carbon fiber wing element includes adjustable struts as well as machined aluminum end plates with the RennTech logo. The rear wing mounting plate with wing uprights attaches to the trunk lid via the included trunk reinforcement mounting plate. This allows the wing to bolt behind the license plate and can easily be removed or installed within 10 minutes.
Features
High quality prepreg carbon fiber finished
Offers a more aggressive, stand-out look
Durability and stunning good looks
Produces greater down force
Installed within 10 minutes
Easily be removed
Perfect design
Renntech Performance Package
Click HERE to order R1 Performance Package!
Click HERE to order R2 Performance Package!
Click HERE to order R3 Performance Package!
Click HERE to order R1 Performance Package for Black Series!
Click HERE to order R2 Performance Package for Black Series!
Click HERE to order R3 Performance Package for Black Series!
The RennTech R1 Performance Package is the perfect entry level performance upgrade for the CLK 63 AMG. RennTech performance package includes our proprietary ECU tune in addition to our full carbon fiber airbox for a gain of +54 HP and +30 TQ over stock. The RennTech R2 Performance Package is the perfect entry level performance upgrade for the CLK 63 AMG. RENNtech performance package 2 includes our proprietary ECU tune in addition to our full carbon fiber airbox, 82mm throttle body kit and RENNtech stainless steel headers for a gain of +76 HP and +58 TQ over stock. The RennTech R3 Performance Package is the perfect entry level performance upgrade for the CLK 63 AMG. RennTech package 3 includes everything found in our performance package 2 plus our stainless steel long tube headers for more performance and sound, our 100% locking limited slip differential to improve handling and traction in addition to our transmission performance upgrade.
Features
Increases Horsepower
Increases Throttle Response
Stainless Steel Shorty Headers
Renntech Performance Carbon Fiber Airbox
Click HERE to order Carbon Fiber Airbox!
RennTech Carbon fiber air box for the Mercedes for M156 - 63 AMG Engines. RennTech full carbon fiber airbox is more than just an impressive under the hood showpiece. By optimizing the path and increasing the volume of incoming airflow, our carbon air box is able to offer gains up to +10 hp and + 10 lb/ft of torque, in addition to serving as an attractive under hood showpiece. RennTech kit comes complete with high flow performance filter inserts and anodized aluminum MAF sensor retaining clips. RennTech electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that RennTech proprietary air box offers incredible performance gains and rock solid daily driver reliability.
Features
Increasing the volume of incoming airflow
Increasing the engine's rev limiter
High flow performance filter inserts
Gains up to +10-15 HP & +10 TQ
Carbon fiber material used
Renntech Aerodynamic Parts
Click HERE to order Rear Diffuser!
Click HERE to order Front Splitter!
RennTech full carbon fiber front lip spoiler offers aggressive front end styling and increased down force for improved handling. Integrated into the flat panel underbody tray are functional channels which allow cooling air to be directed to the front brakes to significantly increase brake cooling and reduce heat fade and pad wear. RennTech front splitter was designed with your daily driver in mind and maintains the same approach angle as the OE front fascia so the RennTech front splitter retains the same clearance for parking stops, curbs and steep driveways. The high quality prepreg carbon fiber construction finished in a beautiful gloss top coat ensures years of durability and stunning good looks. This front splitter is a fully functional aerodynamic component as well as an aggressive exterior enhancement on the muscular CLK and available in matte or gloss finish. RennTech rear diffuser is the companion component to the front splitter and functions to decrease drag and increase down force by improving the underbody airflow and its transition to ambient air. As with the front splitter, rennTech diffuser is the result of countless hours of design and testing, but isn’t just for looks. Integrated into the true double decker rear diffuser are air channels to dramatically reduce turbulent underbody air as well as a dedicated channel to direct air to the rear differential oil cooler, thus decreasing thermal stress on drive line components and allow for significantly cooler operating temperatures.
Features
High quality full carbon fiber front lip spoiler
Unique and aggressive aerodynamic package
Design is perfect as a stand alone component
Significantly increase brake cooling
Aggressive exterior enhancement
Reduce heat fade and pad wear
Increases front end down force
Improves vehicle aesthetics
Beautiful gloss top coat
Simple to install
Renntech Performance Brake
Click HERE to order Renntech Performance Brake Package 1!
Click HERE to order Renntech Performance Rear Brake Package!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
RennTech performance eight (8) piston front brake calipers
Deliver more consistent brake pedal feel
Reduce fade compared to stock
High-performance brake pads
Long-lasting reliability
Renntech Locking Limited Slip Differential
Click HERE to order Renntech LSD!
Simply explained, a differential is the last point between the engine and the wheels where power is transferred. The differential functions as a system to direct engine power at the wheels while allowing them to rotate at different speeds. By upgrading the differential, you benefit in both straight line stability and vehicle handling while cornering. During a full power straight line run, RennTech LSD (limited slip differential) will lock 100% and provide torque equally to each powered wheel, providing stable straight line runs. When exiting from a corner, RennTech LSD's transition to the full 100% lock position is smooth and predictable. This gives the vehicle better traction and stability throughout the corner, improving overall lap times and a noticeable improvement in overall vehicle handling. The track is not the only place where the differential comes into play though. Bad weather and harsh road conditions can make the street a dangerous place. In snow, ice, wet weather and regions where the road surface can become unstable, our LSD easily adapts and adjusts tire rotation to increase vehicle stability on the road and help to dramatically improve driver safety. RennTech differential is a unique, patented, clutch- type LSD which makes this a true100% locking differential. Because of this function, there is no movement of internal parts, leading to less heat being generated while in operation and in turn, less wear of the friction disks.
Features
A noticeable improvement in overall vehicle handling
Provide torque equally to each powered wheel
Provide stable straight line runs
Gives the vehicle better traction
Stability throughout the corner
Improving overall lap times
Provide straight line stability
Increase vehicle stability on the road
Help to dramatically improve driver safety
Renntech Performance Torque Converter Upgrade
Click HERE to order TCU!
The RennTech lock-up clutch upgrade uses a multi-element clutch upgrade with additional layer of friction material between the clutch plate, better friction material on the clutch face and a larger surface area of friction material to help control slippage. This allows for better heat management and increased holding power. While slippage in the torque converter is important under acceleration, this slippage becomes a liability once cruising speed is achieved. The lock-up clutch controls this slippage and creates a solid connection between the engine and transmission. If the load on the clutch is too much, slippage can occur leading to excessive heat and wear.
Features
Larger surface area of friction material to help control slippage
Allows for better heat management
Increased holding power
Better friction material
Renntech exhaust stainless steel sound and performance pipe
Click HERE to order sound exhaust and performance pipe!
Click HERE to order sound exhaust and performance pipe For Black Series!
RennTech performance and sound pipes with integrated x-pipe bypass the stock Mercedes resonators for more volume and a better sound. Combined with RennTech ECU software and stainless steel headers, the sound pipe produces more power in the mid-to-high rpm range. RennTech High-strength 304 stainless steel construction ensures lasting quality and a rich, consistent sound. RennTech electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that RennTech proprietary Exhaust Stainless Steel Sound and Performance Pipe offers incredible performance gains and rock solid daily driver reliability.
Features
Highest quality T-304 stainless steel exhaust headers
More volume and a better sound
Exhaust Stainless Steel Sound Pipe
Stainless Steel Performance Pipe
High quality meterials used
Looking more aggressive
Design is perfect
Renntech Performance Speedshift Valve Body Upgrade
Click HERE to order Speedshift Valve Body Upgrade!
The staple of advanced or professional driving is the "rev match", or "throttle blip", in which the driver quickly brings the engine up to speed with the wheels by use of the throttle. This was not possible with the automatic transmission in the CLK Black Series…until now. RennTech is proud to offer our Speedshift performance valve body upgrade for the CLK black series. RennTech upgrade modifies the shifting performance characteristics of the transmission control unit, the transmission valve body and allows the vehicle to automatically “blip” the accelerator upon down shifts allowing for quicker gear engagement and faster lap times. When downshifting, the engine throttle is increased to allow the engine to match the RPM of the lower gear and allows for significantly faster gear engagement . When coupled with our transmission upgrade, this is the ultimate upgrade for your CLK Black series.
Features
Allows the vehicle to automatically “blip” the accelerator
Speedshift Valve Body Upgrade with Throttle "Blip
Allows significantly faster gear engagement
Allowing for quicker gear engagement
Faster lap times
Renntech Performance Throttle Body Upgrade
Click HERE to order Throttle Body Upgrade!
RennTech proprietary 82mm Performance Throttle body package offers a 22% increase of incoming air volume. This translates into a noticeable gain in both overall performance and throttle response with a performance increase of 11hp & 8 lb/ft. RennTech throttle body assemblies were designed and engineered in house and a re a bolt on component requiring no modifications to the intake manifold. Our throttle assemblies feature a machined billet aluminum housing with custom designed air velocity stacks and all necessary hardware/ electrical connectors to make installation a snap.
Features
Noticeable gain in both overall performance
Throttle response with a performance increase
Increase of incoming air volume
Improve vehicle performance
Easily be removed or installed
Gain 11hp & 8 lb/ft
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
