SRS EPS Warning
Just replaced the worn indicator stalk (wouldn't stay on) with an OEM item. All good, everything working but the Stability Control warning has appeared. I have read that turning the wheel lock to lock a few times will re set this. Sitting at work so can't try this yet. When I got the car the SRS warning is on. The owner said his MB mechanic said it wasn't a problem and something to do with the seatbelt? New to MB but learning fast! Someone on this forum mentioned WD40 in the seatbelt buckle. I'm sure this must have been covered before but a search didn't find anything. What are the most common causes of the SRS warning message?
This same scenario will have happened to someone else guaranteed. I just hope that person reads this thread. If the clock spring unravelled slightly when removed could this cause an issue? i did read someone who said they found the middle point by winding it fully in both directions and counting the turns. When buying the new indicator stalk they don't supply the little red plastic locking pin which is a shame.
http://benzbits.com/w203/Clockspring.pdf
