Adjustment motor adaptive bixenon
Old 03-04-2020 | 07:58 AM
a_raspopov's Avatar
w209 CLK200
Hello everyone!
I want to retrofit my headlights and at the same time solve the problem with adjustment motor. It doesn't work correctly, so i want to replace it.
Can anybody tell me a part number of adjustment motor in my headlight?
VIN WDB2093421F209682.
P.S. Sorry for my English
Old 03-04-2020 | 12:41 PM
Fatz's Avatar
2008 clk550 - Navigator - Frontier
How is your adjustment motor not working correctly? If you mean that it does not adjust to compensate for the car going up or down a hill and/or it points you lights toward the ground, it may not be the motor. It could be the elbow linkage connected to your front torsion (sway) bar and provides a signal to the motor. It could be unable to move (silicon lubricate would correct) or the linkage is in the position opposite to where it should be (requires you to loosen the cap nut holding it and move the elbow to the opposite position). The elbow/sensor is located on the passenger side for US cars.
Or, it could be the motor as you suspect.
Old 03-04-2020 | 12:59 PM
a_raspopov's Avatar
w209 CLK200
Thanks for your answer!
I mean that when I start the engine, my right headlight moves down, but then it doesn't moves up. It happens when it's wet outside or after washing. Maybe it's issue of the block under the headlight?
Old 03-05-2020 | 09:17 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Not sure if it will help but......
https://mbworld.org/forums/clk-class...2-insame1.html
Quick Reply: Adjustment motor adaptive bixenon
