M273 E55 CLK550 Cylinder and Coil Numbering
Old Mar 5, 2020 | 03:07 PM
Sabadara's Avatar
2007 CLK550
Guys I just did a diagnostic on my car because its check engine light was on, and it showed three codes: Coil G,Coil C,and misfire cylinder 7. How can I find out which ones are coil G and C and which cylinder is the seventh?
Old Feb 1, 2025 | 03:19 PM
chandlerclip760's Avatar
08’ CLS550
Know this is very late but on most V6/8 motors the odd number cylinders are on the right or driver side (USA) and even #s on left side or passenger side. So on the M273 if you are looking at the engine with the hood popped, the right side will be starting closest to you(front of motor) 1,3,5,7 and left is 2,4,6,8.
Old Feb 2, 2025 | 09:53 AM
waybomb's Avatar
SL600 r230, SL600 r129, SL500 r230, ML320, C280 Sport, R170 450SL, 190e 2.3 16V (2)
And the plug wire Metal boot is stamped with the location of that wire
They are different lengths.
Old Feb 3, 2025 | 12:14 AM
08’ CLS550
the vehicle being discussed is a direct coil on plug setup. Not sure what metal boot you are referring to being stamped with a location for wire??
Old Feb 3, 2025 | 10:05 AM
waybomb's Avatar
Sorry. Thinking of 113
Old Sep 30, 2025 | 01:32 PM
OKAUSTX's Avatar
2007 CLK550
Is this true? The car has an M273 E55 if I am not mistaken. I am trying to get the same answer, but all info I can find is that cylinder 1 is at the front of the passenger side?
Oliver
