Access problem with dead battery
Old Apr 5, 2020 | 03:00 AM
Rainer Schuett's Avatar
CLK 320 Cabriolet A209
After a longer period of storage of my CLK 320 2005, the battery died totally, so I had to try the physical key to get access. The key turns alright, but the lock pin does not rise, so I still cannot open the door. Anyone out there experienced a similar problem and has a solution?
Old Apr 5, 2020 | 07:00 PM
emoore924's Avatar
c230
If you have a coupe, use the key to open the trunk, the pop the seat backs and climb in through the trunk...
Old Apr 14, 2020 | 06:12 PM
Thanks for the hint. Unfortunately, my W209 is a cabriolet
Old Apr 14, 2020 | 07:39 PM
emoore924's Avatar
c230
Oh well, worth a try :P
Old Apr 15, 2020 | 08:08 AM
JoiseyBenz's Avatar
2006 CLK500 cabriolet
It may sound crazy, but how about this...
Jack up the car in the front - jack stands, etc. for safety.
Try to find the location where the positive battery cable connects to the starter. Attach a jump-start to that, and the negative to the frame somewhere. You would probably just need a small amount of ooph to operate the door lock receiver.
ANOTHER possibility. I just saw a video on www that showed:
1) put physical key into door and turn left all the way.
2) Continue to pull/release the door handle several times. After a bunch of pull/releases it might get the door to unlock.
Supposedly, this approach is a 'security mechanism' by design.
Old Apr 15, 2020 | 09:01 AM
This is an interesting approach, I will try it as soon as I am back home. I have done the very same procedure before, with the only difference that I pulled/released the handle only a couple of times. Could this be a pumping action for a hydraulic actuator?
Old Apr 15, 2020 | 09:02 AM
By the way, do you have the access address to the video you mentioned?
Old Apr 15, 2020 | 12:46 PM
JoiseyBenz's Avatar
Rainer, The fellow in the video pulled the handle about 15/20 times until it opened. He also claims that the reason you have to do it so many times is because of some 'security mechanism' built into the Mercedes vehicles.
Here is the link:
Old Apr 15, 2020 | 12:58 PM
Well, it was definitely worth a try. Sadly enough, it didn't work.....
Next step is "to call the guy".
Old Apr 15, 2020 | 01:10 PM
JoiseyBenz's Avatar
Rainer, I like to do whatever I can to figure out HOW to do it, before I hand my problem off to a 'professional'. If it were me, I'd continue looking on www for other answers. I wouldn't be surprised if they charged you from $50 to $100 to get it open, and it'll probably take them 5 minutes because a dealer (or auto locksmith) surely knows all the tricks.
Here's a MB dealer who is basically suggesting what I said, to apply some power to the system (at the right place) - just enough to get the lock working.
Take a look: https://www.arrowheadmb.com/blog/how...-dead-battery/
Old Apr 15, 2020 | 02:32 PM
HETPE3B's Avatar
Own 2005 CLK500, but drive 2011 Sienna :)
It doesn't matter if it's a coupe or a cabrio. Both trunks can be opened with the key.
Old Apr 16, 2020 | 02:30 PM
emoore924's Avatar
c230
Yes, but I think only the coupe has seats you can crawl through from the trunk?
Old Apr 16, 2020 | 10:33 PM
HETPE3B's Avatar
If you refer to climbing from the cabin into the trunk area then yes - only doable with Coupe I though you referred to the trunk lid.
