Looking for the headlights pinout
When turned on left headlight works as it should (at least seemed to). Right headlight was working for a few seconds and then controller that is mounted on the bottom of the headlight burned down. 3 controllers later plug that was plugged into the controller also melted
, so I need a wiring harness for the right headlight
Also I need the wiring diagram for 08 and 05 xenon headlights to compare it - I still don’t know if the wiring it different in those 2 connectors that are matching in size or the problem is with the wiring inside the headlight.
if someone have internal wiring for 2005 xenon headlights- let me know as well
C1 connector (5 pin I guess) is the same though.
