breeze247
close
- Join DateMay 2017
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveW209 CLK55 - 2003
Liked:31 Times in 24 Posts
Hey all
i have a 2003 CLK55. When I got the car I remember being able to unlock with the blade key. I don’t recall needing to do anything specific with it to get the door to open. Some time after getting the car, I replaced the Keyless handle with a used replacement. I didn’t change the lock.
3 years later, when I try the key in the lock, the barrel will turn but the door will not unlock.
When I look online, lots of people talk about turning the key left and then having to pull the door multiple times. I must say that I don’t remember needing to do that. Car is UK right hand drive by the way.
Questions:
- Can somebody describe exactly what the blade key opening procedure is?
- Is there a chance that I did knot refit the lock correctly? I wonder if there is an easy mistake there.
- Are there any other known faults/weaknesses in the door lock mechanism that could give the same symptoms?
Thanks in advance.
Questions:
Thanks in advance.
Broken spindle
Mock homemade spindle I made from an old screwdriver but couldn’t get the cotter pin hole drilled because the metal was too hard.
Homemade spindles. I used the one on the right made from a machined bolt that was put on a lathe to remove threads and then ground the head to a chisel point.
I just took the return spring off of the back of the lock mechanism and used a cotter pin to secure my homemade spindle.
