Drivers door keeps unlocking
When I'm sitting in the car, every 5 seconds I can hear the lock clicking. The clicking is the lock actually trying to unlock
If I lock the car from inside, 5 seconds later the drivers door unlocks on its own. If I lock the car from outside, 5 seconds later the drivers door unlocks on its own.
I do have DAS softare which shows no errors in the ignition or door control modules
The only clue it gives is when checking ACTUAL VALUES in the left door module. Its shows SIGNAL CENTRAL LOCKING as NOT OPERATED, then every 5 seconds (along with the dreaded click) the signal changes to OPEN for about a second
Any pointers on where to start looking for the cause of this please?
"...when checking ACTUAL VALUES in the left door module. Its shows SIGNAL CENTRAL LOCKING as NOT OPERATED, then ..."
What do the *other* door modules show, when they are closed and open? More specifically, do they also show "NOT OPERATED" when open? Or do they show "OPEN", or something else?
If I'm right, this value should be either OPEN or CLOSED. Showing "NOT OPERATED" may mean that the door lock, when in closed position, is not transmiting the signal that it is "OPEN" to the locking system.
In that case, I would remove the door card, and try to shower the lock with WD40, while locking and unlocking it manually, and watching the ACTUAL VALUES for it.
Then again, I might be wrong. This is largely guesswork, since I never had issues with the door locks on my CLK. Good luck, and let us know how it goes.
