Strut Assembly
Old Mar 13, 2021 | 03:11 PM
7r3y's Avatar
2005 Mercedes-Benz CLK320
Strut Assembly
I have an 2005 CLK320 that I can't find a strut assembly for, I've looked everywhere. Despite of that, there is a strut assembly for the 2005 CLK500. I was wondering if the struts for the 500 will fit on the 320.
Old Mar 13, 2021 | 06:57 PM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
They will fit but they ought to be stiffer as they were meant to hold up the heavier v8.
Old Mar 13, 2021 | 10:05 PM
7r3y's Avatar
That it will be stiffer, will it effect the way the 320 drive negatively?
Thanks.
Old Mar 13, 2021 | 10:59 PM
dzmitry's Avatar
2023 E450 AT, 1996 S420, (sold) 2004 CLK320 Convertible (v8, 6 speed)
Thanks.
Couple of questions:
1. Why are you looking for strut assemblies ? You don't want to deal with installing springs? Usually most of indy shops will be able to assemble/disassemble struts for a small fee.
2. Be aware that there is two types of from struts: for "sport suspension" and for "non-sport suspension". The difference between them is a hole size for sway bar links. 12mm and 10mm accordingly. I can tell you which one you need by using for example this resource https://www.lastvin.com/. But I think all clk500 for US marked have sport suspension.
Old Mar 13, 2021 | 11:57 PM
7r3y's Avatar
Yes, the moral is I don't want to deal with the springs. But since you mentioned that indy shops will assemble/disassemble for a small fee, I'll inquire before purchase.
Thanks.
Old Mar 14, 2021 | 12:22 AM
nkx1's Avatar
2010 E550 Coupe
Where did you find the assemblies for the 500?
Old Mar 14, 2021 | 01:02 AM
7r3y's Avatar
partsgeek.
Old Mar 14, 2021 | 12:05 PM
scourchaine's Avatar
2006 ML500 #4JGBB75E45A047014, 2005 CLK500 WDBTK75G25T052675, 2004 e500 4matic #WDBUF83J54X123761
clk500 struts
I just purchased a '05 clk500, for my wife, that is very well optioned including #486 sport suspension.
FCP Euro, Parts Geek, Rock Auto, Tire Rack and others make special note these are not for "sport suspension". I'm wondering if this is accurate. I have NOT found any struts for a "sport suspension" version.
What is the difference between a regular version and a "sport suspension" option car, if any?
Lastly, if in fact they are different, where can you purchase the correct struts/shocks?
Thanks a ton, Scott
Old Mar 18, 2021 | 02:28 PM
7r3y's Avatar
Do think it is best to get CLK350 strut assembly over an CLK500 strut assembly?
Old Mar 18, 2021 | 10:11 PM
ambit's Avatar
09 CLK550
I purchased 2 x Bilstein W0133-1941358 from partsgeek in Dec for my 2009 CLK550 (with sports suspension #486)
Its just the bare strut, not the whole spring assembly. $109
