Another top problem
Old Jun 12, 2021 | 08:13 PM
fv9's Avatar
fv9
2008 CLK 350 cabriolet
Another top problem
The top has stopped working on my 2008 CLK 350. I hear the windshield lock move and it starts to lift, then stops. The rear bow raises and the tonneau cover begins to lift and then everything stops. I have reviewed tons of threads on these issues but havent found anything specific to my issue. I was also emailing with Klaus at Top Hydraulics, Inc (thank you so much, Klaus) and he suggested I check the connections and rider on the left case cover cylinder as the hydraulic fluid was dead center so he thought microswitch. When looking at it, everything appears to be plugged in and the rider appears secure. So at this point Im at a loss. Any advice is greatly appreciated. Thanks!
Old Jun 13, 2021 | 01:48 PM
OR-CLK350's Avatar
CLK350 2007
I had a similar problem a couple of years ago, and ended up taking the car to the MB dealer (Wilsonville, OR). After the diagnosis, it turned out to be 2 (yellow) relays located close to the pump… I ended up paying for the diagnostic, plus two $12 relays.
Hopefully, your problem is as simple…
Old Jun 13, 2021 | 02:04 PM
fv9's Avatar
fv9
I was reading about that this morning. I’m not far from you (Camas) and was about to head to the Washougal Autozone for new relays. Fingers crossed.
Old Jun 13, 2021 | 03:05 PM
fv9's Avatar
fv9
Sadly, new relays did not solve the problem. Guess Ill have to pay for diagnostics to be safe.
Old Jun 13, 2021 | 03:22 PM
OR-CLK350's Avatar
CLK350 2007
The MB part number of the 2x relays used on my repair is 002 542 74 19
Also, FYI, if the trunk lid is not working be aware the assist system will stop responding after certain number of failed attempts… and it has to be “re-normalized” at the dealer for it to work again.
Old Jun 13, 2021 | 03:26 PM
fv9's Avatar
fv9
Good to know. I appreciate it. It does pop up and back about an inch. Hopefully that’s enough to avoid having it cease operation.
Old Jun 17, 2021 | 03:04 AM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
I just needed a new hydrolic actuator. It was like $600 from MB, so about $900 total at my BOSCH place.
Old Jun 18, 2021 | 01:51 PM
OR-CLK350's Avatar
CLK350 2007
Good! Any chance you can share the P/N?
