Seicane Command Center Replacement for 2009 CLK 550 with HK system
Old Jan 8, 2022 | 12:20 PM
spsc01's Avatar
2009 CLK 550 W209
Has anyone replaced their audio head unit with this Seicane Head made for the later W209 models?
https://www.seicane.com/android-gps-...te-1080p-h2697
If so, what's your experience? How well does it perform? Did they provide the correct harnesses? Did it plug correctly into the car's harness plug? Is the 32GB memory expandable? If so, how? Did you use an optical converter or run new copper to the trunk? If new copper, did you use an amp to connect the Seicane unit's amp directly to the speakers? If you used their b/up camera, how did it perform? Anyone use the wireless B/up camera? Did you replace any speakers that fit into existing space with existing covers? Thanks in advance
Old Jan 17, 2022 | 06:25 PM
spsc01's Avatar
2009 CLK 550 W209
MODERATOR: PLEASE DELETE THIS POST FOR ME. 1ST TIMER CREATED DUPLICATE POSTS. THX, STEVE
