Are all CLK Headlights the same size?
Old Apr 20, 2022 | 08:24 AM
Shack_Attack's Avatar
CLK350 Cab
Hi All, Newbie here
Just picked up a CLK350 Sport, with the old style Halogen (non projector) Headlights
I've seen a couple of OEM Projector ones on ebay which I'm looking to retrofit.
Bar the coding through STAR to tell the car it now has Xenons, are these a simple plug and play swap?
Old Apr 21, 2022 | 03:13 AM
Suzilovesmbz's Avatar
2008 clk350
Headlights
Originally Posted by Shack_Attack
Hi All, Newbie here
no they are not all the same. I did buy the plug n play projector led headlights for my 2008 clk350 and i dont think they fit as they should. However i can see forever at night and like that! Seems?like they need a bracket or seal to fit in better
Old Apr 21, 2022 | 04:26 AM
CLK350 Cab
The ones I'm looking at are the OEM Projectors from an older car, I'm hoping they just retrofit straight in as from research MErcedes didn't change the headlights on the facelift?
Old Apr 21, 2022 | 08:06 AM
Greg Northcott's Avatar
CLK350 Convertible 2007 W209
Lights
Hi All, Newbie here
your better off replacing the standard Halogen globes with an LEDs for H/L Beam. Far easier, cheaper and better light.
Old Apr 21, 2022 | 10:31 AM
CLK350 Cab
Keeping the existing normal headlights Greg?
Won't the dazzle to other drivers be crazy?
Old Apr 21, 2022 | 04:46 PM
you will only have to worry about low beam. Buy quality LEDs Osram. Phillips etc that have the correct cut off. Give that a try and see how you go. It's a cheap and effective start.
