Stuck in limp mode :( help
I had no issues with the car until sunday when after getting of a freeway and make a complete stop, i felt the car was weak, like when one tries to start moving a car from 3rd gear or so (a manual one). I was able to move anyways and pull over on a quiet street. I out the car in P, turned it off and back on. Then i put it on D and it went right into gear. It moved but didnt upshift, then i noted a check engine light and also realized that my C and D letter were missing on my dashboard. The lever is NOT stuck, i can put the car in R N D and P put that wont be displayed on the dashboard.
As i dont have the diagnostic tools for a mercedes, i took it to a near shop where they an inspectio and autologic scan. The inspection showed leaking from the transmission pan and the autologic scan showed all the previous CAN codes that i had a couple new ones:
EGS52 (SERIAL) 722.6
P2310
P2311
P2312
P2313 (Was already there)
P2314 (Was already there)
P2315
P2316
The garage told me they think this is related to the CAN bus problem and that they will need to remove the carpet to test all connections there and want charge me 800 usd for it. I read a lot of 722.6 trans have issues with the adapter plug and the conductor plate and that these are a MUST check if you are in limp mode and have a leak. However, they said this is not related without even checking these.
Do you agree that the best way to proceed is checking connections instead of checking the adapter plug and conductor plate? or this garage just trying to squeeze my money? Should i bring the car back home and try to address the leak first before taking carpets off?
Thanks so much, any help is welcomed!
I then looked for the TCM under the passenger's carpet. To be honest it was bone dry and all the pins and connectors were rust and corrosion free. Of course i couldt open the TCM itself but base on the findings i dont think the problem is there.
Is there any way of testing the TCM ?
If not, or if the testing is normal i guess i will proceed with getting a new conductor plate.
Once again, any help is welcomed! I am just posting my progress in case it helps someone else.
