couple issues after changing rear window regulator
I have a 2005 CLK320 cabriolet. I replaced the passenger rear window regulator and after buttoning everything back up, I have 2 issues. Note that the rear window now rolls up and down properly. However:
- the SRS error is lit on the cluster. Is this typical after having disconnected (and then reconnected) seatbelt wires?
- when opening passenger door, usually both the door window as well as the rear window will move a little bit (1/2" each) and when you close the door they will then move back. However, now only the front window moves when I open the door, the rear window doesn't and therefore when I close the door it collides with that rear window and is difficult to close the door unless I slam really hard or if I use my hand to push that rear window back just a tad. When the door closes, the rear window will move back to the correct position.
Aside from the obvious - verify that all the wire harnesses were reconnected properly, you may need to do a "power window sync". The procedure to reset the windows and sunroof are in the manual, but I believe you put all the windows down and keep holding the buttons for 3sec. You need to do this any time power is disconnected.
