7g 2-3 hard cold shifts
CLK W209 m272
Hi, cannot find anything for 6 months so im coming here.
I have a 2005 W209. When transmission has completely cooled down, the 2-3 shift is long, delayed. Always in the morning I have to drive out of the garage up the hill. When im leavin garage the transmission during first shift (usually during leaving garage) has very long break between gears (only 2-3), I even had situation it just stopped because it lost momentum. When I had car parked on normal parking lot and the car stood for as long to be cold the first 2-3 shift is also hard, delayed
The weirdest thing is that ONLY first 2-3 shift is such long, after one shift next 2-3 shifts are still hard but not delayed for as long as first one. Transmission after getting to operating temperature is smooth as silk.
I sent the car to the mechanic. STAR showd Y3/8n2 error, replaced - nothing changed, oil and filters replaced - nothing changed.
After this time and trying to find the solution I simply dont know what to do, the car itself is awesome but driving with this transmission - terrible. Anybody had similar problem?
#edit, wrote this 2 weeks ago, today magnificent 7g tronic tried to drop from secound to first gear while going up garage, after (ofc delayed) change it just stoped, when i pushed gas pedal it barely moved and when I relieved gas pedal car would go downhill.
Last edited by newbier18; 01-02-2024 at 05:09 PM. Reason: new information about shift
I have an '03 with the 5 speed auto and have to say this car is the worse when it's clock cold. I read that it's something to do with emissions, the car holds on to gears to warm up quicker, drives normally after about 5 minutes. Doesn't happen any time other than when it's been stood overnight. I know it's normal so I don't worry about it.
However, @Mh159 might want to check the exhaust system for any leaks. When I first got this car there was a small leak on one of the joints, not enough to be noisy but enough to mess with the car when it was cold. Got the leak sorted and early morning driving was better.
CLK W209 m272
Hi, after this time and mine search the problem is often mentioned one of the lockup valve, despite the lack of engine rpm fluctuations. I will be trying to locate specific valve and will return here with feedback. If anyone have simillar problem you can contact me within discord - kubus667 (I hope this's not breaking regulations of mbworld). This problem's common and can cause faster wear of transmission.
CLK W209 m272
CLK W209 m272
I will get you know if this helped probably in a month, gonna check and replace after paycheck. lock-up is a Solenoid on valve body
