Coolant fluid low / Windshield fluid low permanent on the dashboard
Subscribe
May 29, 2025 | 05:46 AM
Hi everyone, I need help diagnosing an issue with my Mercedes CLK (W209).
The coolant level and windshield washer fluid level check messages are permanently displayed on the dashboard.
A while ago, I unplugged the windshield fluid sensor since it didn’t trigger any warning even when empty. The sensor’s board looked fried, and a multimeter showed no resistance, unlike a new one which shows 180Ω.
After removing it, both messages for the coolant and windshield fluid are displayed permanently on the dashboard and won’t clear, even after replacing the broken sensor.
Here’s the strange part:
Neither sensor’s connector has voltage, even with ignition on. On my dad’s W203 (same wiring and parts as W209), they get 5.5V.
Looks like the SAM isn’t supplying power to the sensors. Why would that be? Can I supply 5.5V externally? Could it be a relay on the SAM I can replace, or is this a deeper issue?
I’m stuck and would appreciate any ideas.
I have attached a wiring diagram below.
Reply 0
Jun 2, 2025 | 11:25 AM
The first thing I would check is the connectors. If they get corroded inside they can cause all kinds of issues. It is possible that something in the connector broke when you removed it and is no longer making a circuit.
Reply 0
Jun 3, 2025 | 06:05 PM
Not the connectors sadly, I removed the connectors and tested the live wires, still no power :/
Reply 1
Subscribe
Currently Active Users (1)
