Do I have a parasitic drain...
I have tried to measure the draw on the battery by hooking up the ammeter in series on the negative terminal of the battery and also by using a clamp style meter with the negative battery hooked up. The best I can tell, after about 6 mins, the draw was reading between 6 and 8 milliamps which seems really low.
I have also been monitoring the voltage in the battery to see if it goes down. After a short drive last night, the voltage registered 12.6 volts. This morning, it was 12.44 and 9 hours later, it is 12.33. The battery is relatively new (less than 12 months) and shouldn't be bad.
I thought a draw less than 50 milliamps was generally considered acceptable. My readings are under 10 milliamps. (Guage says .007)
Should I be concerned that the volts have dropped below 12.4 in less than 24 hours?
The local MB dealer determined the cause of the battery drain as "current draw on circuit 9" and further diagnosed it to "rain sensor control unit (in compartment above rear view mirror) was defective and not going to sleep" which is on that circuit.
I have a new (eBay) rain sensor ordered. While I am waiting for delivery of new sensor, I was trying to confirm the findings to make sure I understood how to test and troubleshoot so I can confirm it is fixed by the new part. Looking at my readings, I think I am doing something wrong, or I don't have a parasitic drain. What are your thoughts?
Thanks in advance for any response.
