Report on Fuzion + Axis wheels
99 CLK 320, 2000 GSXR 750
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Well fellow MB'rs, it has been a while since I visited. So here it goes...
1. I have now gotten about 20K on my Fuzion 235 /35 x 19 tires on a set of Axis 7's with the max lip option (means I can get away with 8.5 rims and still have the staggered look).
2. Additionally I have the speedybenz dog bones and KMAC front kit, also aftermarket springs and shocks.
3. Recently I took off the wheels and tires because I saw an interesting problem, the front inside edge of the tire (both fronts only) was COMPLETELY grooved by the upper bolt from the ball joint (and nut). This pisses me off since I spent so much money trying to get the camber right in the first place. Now that I have that right, I have this bolt and nut cutting a 1/2" deep and 1/2" wide groove all the way past the wire mesh built into the tire. Besides this the tires were holding up fine. Infact I am told I was probably running like that for months. Talk about FREAKING out...One blow out is manageable but both fronts...that aint right!!!
Question
How are the rest of you dealing with 19" rims with the correct offsets? I am running spacers in the rear but none needed in the front. Is this an offset issue?
Thanks and these Fuzion X series tires rock...the rims have held up surprisingly well with all of the crap I put them through...
Cheers,
Ben
Question
Cheers,
Ben
Originally Posted by benzinoben
... Recently I took off the wheels and tires because I saw an interesting problem, the front inside edge of the tire (both fronts only) was COMPLETELY grooved by the upper bolt from the ball joint (and nut). This pisses me off since I spent so much money trying to get the camber right in the first place. Now that I have that right, I have this bolt and nut cutting a 1/2" deep and 1/2" wide groove all the way past the wire mesh built into the tire. Besides this the tires were holding up fine. Infact I am told I was probably running like that for months. Talk about FREAKING out...One blow out is manageable but both fronts...that aint right!!!
