2007 CLK63 Specifications
Old Jul 1, 2006 | 05:42 PM
Peanuthead's Avatar
2009 C63 AMG
Talking 2007 CLK63 Specifications
I have the specifications for the 2007 CLK550, CLK63, CLS550 and CLS63 AMG's.
I will post the data in each of their respective forums.
This data should be available on the mbusa.com site soon.
I am posting only the pertinent information, including:
* Engine and Drivetrain
* Chassis
* Performance
* Exterior Features
* Interior Features
* Instrumintation
2007 CLK63
MSRP TBA
EngineAMG-built 6.3L DOHC 32-valve V-8
Net Power475 hp @ 6,800 rpm
Net Torque465 lb-ft @ 5,000 rpm
Engine and DrivetrainEngine 6,208-cc AMG -built DOHC 32-valve V-8. High-pressure die-cast alloy cylinder block. Alloy heads.
Reinforced engine block, oil pan structure, pistons, connecting rods, crankshaft, and valvetrain.
Net power 475 hp @ 6,800 rpmNet torque 465 lb-ft @ 5,000 rpmCompression ratio 11.3:1Fuel requirement Premium unleaded
gasoline, 91 pump octane.Induction Dual overhead camshafts with continuously variable intake and exhaust timing. Magnesium
2-stage resonance intake manifold with two internal throttle flaps increases intake runner length at lower rpm for improved
response.
Fuel and ignition system Integrated sequential multipoint fuel injection and phased ignition includes individual cylinder
control of fuel spray, spark timing/phase, and antiknock. Electronic throttle. High-energy ignition coil and two spark plugs
per cylinder. 100,000-mile spark plug intervals.
Transmission AMG-enhanced 7-speed speedshift automatic. Electronically controlled shifting. Driver-adaptive programming
adjusts shift points to the driver's current driving style. Touch Shift allows driver to manually downshift as well as
upshift by nudging the shift lever left or right of the Drive position. Shift into Optimum Gear programming allows one-touch
selection of the best gear for maximum acceleration or engine braking by holding the shift lever to the left of Drive for one
second. Driver-selectable Comfort mode starts the vehicle moving in 2nd gear, or a second Reverse gear, and upshifts at lower
rpm, to help improve control on slippery surfaces.
AMG Speedshift with direct Manual control AMG SpeedShift™ programming provides up to 35 percent faster gear changes,
automatically downshifts during braking, prevents unwanted upshifting while cornering, and features torque converter lockup
in all forward gears. Manual mode allows direct-access shifting through forward gears via paddles on back of the upper
steering-wheel spokes (left paddle downshifts, right paddle upshifts) or via Touch Shift feature of shift lever, and will
automatically intervene only to select 1st gear when the vehicle stops. In Standard and Comfort modes, the steering-wheel
paddles operate the Touch Shift feature.
Drive configuration Rear-wheel drive.
Rear axle ratio 2.65:1
Chassis
Front suspension Independent 3-link with antidive geometry. Enlarged stabilizer bar. AMG sport suspension with AMG-calibrated
front and rear coil springs, stabilizers, and shock absorbers.
Rear suspension Independent 5-arm multilink with geometry for antisquat and alignment control. Enlarged stabilizer bar. AMG
sport suspension with AMG-calibrated front and rear coil springs, stabilizers, and shock absorbers.
Steering type Rack-and-pinion with vehicle-speed-sensitive power assist and integrated hydraulic damper.
Turning circle 35.3 ft/10.76 m curb-to-curb.Steering wheel turns 3.0 lock-to-lock.Wheels 18" polished AMG 5-spoke alloy
wheels with inner spokes painted in titanium gray.1
Tires 225/40 ZR18 front and 255/35 ZR18 rear, high performance.1
Brakes AMG-enhanced dual-circuit power-assisted 4-wheel disc brakes. 14.2" compound perforated and internally ventilated
front discs and 13.0" internally ventilated rear discs. AMG 6-piston fixed front and AMG 4-piston fixed rear calipers.
Antilock Braking System (ABS) ABS senses impending wheel lockup under heavy braking and pumps the front brakes individually
or the rear brakes together (to help maintain stability) as needed up to 30 times per second, to prevent lockup and maintain
steering ability.
Brake Assist Brake Assist senses emergency braking via the speed at which the driver presses the brake pedal and immediately
applies maximum available power boost, potentially reducing the overall stopping distance by eliminating the delay caused by
a common human tendency not to brake hard enough, soon enough. Letting up on the brake pedal releases Brake Assist.
Performance
Acceleration1 0 - 60 mph in 4.5 seconds
Fuel economy EPA estimate2 TBA mpg
Highway estimate3 TBA mpg
Emission certification TBA
Exterior Features
Black grille with three chrome ribs.
AMG-designed front air dam with mesh air intakes and chrome-ringed round front forlamps. AMG-designed side skirts and rear
apron.
Color-keyed AMG-designed rear spoiler on the edge of the trunk lid.
AMG sport exhaust system with twin chrome tailpipes.
Red and smoke-color rear lamp covers.
Electrohydraulic insulated all-season soft top with flush-bonded glass rear window. Fully automatic operation allows soft top
and all four side windows to be lowered or raised from a single control on the console or from outside the car using the
SmartKey remote.
Dual power mirrors, linked to driver's seat memory and automatically heated.
Auto-dimming left-side mirror.
Electrically heated rear window with auto-shutoff based on time and outside temperature.
Dual aero-blade windshield wipers. Heated windshield washer nozzles.
Infrared rain sensor automatically adjusts the wiper speed and intermittent wiper frequency from infinite delay to fast
wiping speed based on the amount of rainfall measured on the windshield.
Heated windshield washer reservoir and fluid lines.
Variable-focus halogen headlamps with clear high-impact polycarbonate lenses.
Halogen front foglamps in front apron. Single red rear foglamp integrated in left taillamp cluster.
Driver-selectable light-sensing headlamps can be set via the Auto position of the headlamp switch to automatically illuminate
in darkness, and when entering dark tunnels or parking garages.
Driver-programmable daytime running lamps illuminate low-beam headlamps at reduced intensity (full intensity for optional
Bi-Xenon headlamps) in daylight, with auto-on override in darkness.
Automatic lamp substitution uses a nearby lamp if a critical bulb fails.
Touch Turn Signals flash three times with one touch of the turn-signal lever, for lane changing. Auxiliary LED turn-signal
indicators are integrated with side-mirror housings.
Interior Features
Digital Dual-zone CFC-free automatic climate control with individual left and right digital temperature controls, and
automatic control of blower speed and airflow distribution (with manual override). Sun sensor. Humidity/dewpoint sensor helps
reduce window fogging during humid weather, and helps prevent overdrying of cooled air. Activated charcoal filter with
smog-sensing automatic recirculation of filtered cabin air. Dash-top diffuser vent. Rear-cabin air vents at rear of front
console. Electrostatic dust and pollen filter. Tunnel mode offers one-touch closing of all windows and cabin air intake by
pressing and holding the air-recirculation button. Pressing button again restores the previous window positions.
Multifunction steering wheel provides convenient, additional controls for basic functions of the audio system and optional
phone, plus operation of the multifunction display. AMG shift paddles located behind the steering-wheel spokes. Power front
and rear side windows with one-touch express-up/down for front windows. One-button lowering or raising of all four windows
via the power top switch. Fine-mesh wind deflector fastens over the rear seat area or folds into the molded case for storage
in the trunk.1 4-way (tilt/telescoping) power steering column, position-linked to the driver's seat memory. Electronic cruise
control. Delayed-shutoff front courtesy lamps. Entrance lamps in both doors. Dual front reading lamps. Dual sun visors with
illuminated vanity mirrors. Auto-dimming rearview mirror. Front center console with rolltop cover, enclosed storage
compartment and removable dual cupholders. Retractable-storage container. Pockets in both doors. Parcel net in right front
footwell. Magazine pockets on both front seatbacks. Folding rear center armrest. Illuminated, carpeted trunk. Variable trunk
compartment allows soft-top well to be used for additional cargo capacity with the top up. Integrated garage door opener.
Seating & Trim
AMG high-grade nappa leather upholstery on seats, and door panel center sections. AMG sport seats with supportive side
bolsters, AMG cross-piping design and AMG logos on backrests. 10-way power front seats, each with 3-position memory. Driver's
seat memory includes steering column and outside mirror positions. Heated front seats. Multicontour driver's seat with
pneumatically adjustable side bolsters, dual lumbar supports, and thigh support. Easy-entry system. When either front
seatback is tipped forward, the entire front seat moves up and forward for easier access to the rear cabin. The seat returns
to its previous position when the seatback is returned to upright. Dual individually contoured rear seats. AMG-designed Nappa
leather upholstery and door-trim inserts, with carpets, dashboard, consoles, and door panels in black. New AMG ergonomic
sport steering wheel with increased contouring, perforated leather and large aluminum shift paddles. AMG-designed
leather-trimmed 4-spoke steering wheel and shift knob. Leather-trimmed shift knob with chrome trim. AMG-designed aluminum
trim with sand-cast finish on doors, dashboard, and console. Polished chrome outlining for wood or aluminum interior trim and
vent registers. Stainless-steel door-sill trim with AMG insignia. Velour floor carpeting and exclusive AMG floor mats. Audio,
Navigation, and Communication
AM/FM stereo/weatherband radio with in-dash single-disc CD player. In-dash audio system operating panel integrates controls
and displays for the radio, CD player, optional glovebox-mounted 6-disc CD changer, and optional portable digital telephone.
Auxiliary input jack in glovebox allows connection of an MP3 player to the audio system. harman/kardon® LOGIC7® digital
surround-sound system: 1 2 speakers (Coupes) or 10 speakers (Cabriolets), including dual surround speakers and a subwoofer;
7.1-channel amplifier with 320 watts (Coupes) or 240 watts (Cabriolets) total output; multichannel digital surround-sound
technology developed for the professional recording industry, to provide a natural and realistic sound stage; Digital Dynamic
Volume Control, to help preserve the sound balance under all driving conditions. Fiber-optic network offers precise,
high-speed communication among components. Tele Aid system uses GPS satellites plus a cellular link to provide 24-hour live
assistance for emergency aid (SOS button), information (i-button) or Roadside Assistance (Wrench button). Basic Tele Aid
Security & Care Package includes Automatic Collision Notification, Stolen Vehicle Recovery, Remote Door Unlock service, and
Dealer Connect.
Instrumentation
AMG-designed black gauges with soft backlighting, black matte surround, and AMG RACETIMER. Digital display for odometer and
Touch Shift gear/mode selection. Multifunction display in speedometer face can be scrolled via the steering-wheel controls to
operate and display various menus and vehicle features including the resettable trip meter and outside temperature indicator,
digital speedometer, maintenance system, engine oil-level check, radio station, CD player, CD changer (optional), iPod
playlist/track (with accessory iPod Integration Kit), navigation system route guidance (optional), vehicle reminder and
malfunction messages, driver-programmable settings for instruments, lighting, vehicle, and convenience features. Also
includes controls for trip computer (elapsed time, fuel consumption, distance to empty) and optional cellular phonebook.
Mercedes-Benz maintenance system displays the distance remaining to the next basic maintenance service, indicates the type of
service due, and provides an automatic reminder feature when the service interval draws near. Audible reminders and messages
for open door or sunroof (if equipped); exterior lamp failure; low fuel, engine oil, coolant, and washer fluid; and to
release parking brake, switch off headlamps, and remove the ignition key.
Old Jul 1, 2006 | 06:39 PM
ItalianStallion's Avatar
R35 GT-R, EvoX
Perfection!
Thanks for the info man.
