Are the brakes between a CLK55 same as CLK63
Old Jan 26, 2013 | 06:02 PM
  #51
ChiCho55AMG's Avatar
W209 CLK55 AMG Kompressor, ATV BRP 800 CAN-AM
PLEASE HELP !!!
Please Help ! The pictures are attached in my previous post,i need to know if they are for the 05-06 clk55,so i can buy them and put them on my 04 clk55. Thanks
Old Jan 27, 2013 | 10:05 AM
  #52
AMGDave's Avatar
300D, 500E, E420
Originally Posted by chicho55amg
Hey guys,would like to ask for some help, is this w209 clk 55 05 brakes or W211 E55 brakes ?
Those are 8-pot fronts. Looks like W211 E55 to me.
Old Jan 27, 2013 | 12:41 PM
  #53
mmm so they wont fit on my car
Old Feb 27, 2013 | 10:12 PM
  #54
Nero Tenebre's Avatar
W209 CLK Renntech Widebody, C140 CL600 V12, AP2 S2000, NSX Twin Turbo, R8 V10
Originally Posted by C_DirtyTwo
Does any one know if there is a decently priced replacement rotor for the CLK63 brakes with the 2 piece 360mm rotors?
Does anyone sell just the ring, and re-use the old hat? This has to be a cheaper option than purchasing brand new 2-piece rotors, I know Racing Brake makes them for the 340mm's, but who makes them for 360mm???
Looks like RacingBrake is interested in making them now if we have enough buyers!! Who is interested?
Old Feb 27, 2013 | 10:20 PM
  #55
C_DirtyTwo's Avatar
a land yacht.
I will be when mine wear out!
Old Mar 1, 2013 | 08:09 PM
  #56
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
Two piece rotors for CLK55 & CLK63
Please join discussion by clicking the thread below for the development and availability of CLK brake rotors:
https://mbworld.org/forums/5562924-post3.html
Old Mar 16, 2013 | 02:44 AM
  #57
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
My question is are the rear brakes from a CLK55 and CLK63 the same? Or did the CLk63 get a rear rotor upsize? Pic of my rear brake (which I saw identified as a 55 rear in another thread), My rear rotors are 26mm wide and corss drilled/slotted
Old Mar 16, 2013 | 04:36 AM
  #58
cm60k's Avatar
Yes sure, if you have the Rears like in the pic.,
that means you have the same "SLK55/CLK63" brakes set-up.....
ZAYED,,
Old Mar 18, 2013 | 07:05 PM
  #59
Not sure lowpost- but the racingbrake website confirms that the C63 has the same rear as the non BS CLK63.
Even other vendors say they have the CLK63 non BS rotors "in stock" because they are used on other benzes. RB actually researched it and confirmed the C63 was the same rotor and offset. You can go to their website and see what's compatible with what--
Old Mar 19, 2013 | 02:07 AM
  #60
lowpost's Avatar
Thanks. I've come to the conclusion I have the slk55/clk63 f/r setup, which is the 030 package available on the 05-06 clk55?
Lol I should know I bought them brand new but cant remember and can't find my receipt.
Old Mar 19, 2013 | 04:41 PM
  #61
I think that package is the clk63 AMG standard brakes... I forget now though that I finally found my replacement rotors and can move on!!
Old Mar 21, 2013 | 02:26 AM
  #62
CLS550
Check it out from our complete two piece rotors list for your MB below:
http://www.racingbrake.com/MERCEDES-s/5788.htm
When you find your model/year, just click the item to the right and it will get you to the detail descriptions with rotor dimensions.
Old Mar 21, 2013 | 09:45 AM
  #63
List needs updating? Looks like some were missing like the CLK63 rear, or labeled incorrectly just FYI- "SLK55 AMG (W209)"
Old Mar 21, 2013 | 11:17 AM
  #64
CLS550
Thanks for pointing out, we will look into this and update the list for more coverage and accuracy.
Although we believe we have most of the late models/years covered (By dimensions), but we may still miss some due to offset and/or retaining holes variation
Since MB has so many models/years which is almost impossible for us to list them all (application wise) so we encourage you check the dimensions of your rotors to make sure they are the right size for your MB and let us know any application we might be missing.
We will add dimension drawing for those items already made available, and also a typical drawing so anyone can't not find from the list can down load the picture, make measurement and send it back to us for identification.
These are typical Front Disc sizes (Diameter x Thickness in mm):
390x36
360x36
360x32
350x30
340x32
340x30
These discs can be assembled with different hats for different offset (rotor height) for different calipers.
Rear Disc:
360x26
330x26
345x26
320x24
In addition to rotor height (offset) like front, rear rotors can also vary by the emergency Drum Sizes (Inside diameter x Shoe width) which has the following different sizes:
165x25
180x25
185x35
210x30
Old Mar 25, 2013 | 12:06 PM
  #65
AMGDave's Avatar
300D, 500E, E420
FYI, your link above lists the E55 AMG W210 along with W211, this is incorrect... the W210 chassis was from 1996-2002 only, and has completely different brakes compared to the W211. The W210 E55 AMG (through 2002) uses factory 2-piece 334x32 front brakes, and 1-piece 300x22 rear brakes, and I don't believe you currently offer either of those sizes. (???) Your application chart should show W211 only (i.e., remove mention of the W210).
Now, if you could create a rotor package for the W210 E55 AMG, that would be awesome! The W210 E55 rotors are the same as the W202 C43. And, the late R129 (1999-2002 SL500 & SL600) uses the same sizes, but with a different hat offset on the fronts. So if you did develop rotors in these sizes (334x32 and 300x22), they would fit multiple different different chassis/applications. Hint, hint!
Old Mar 26, 2013 | 05:11 PM
  #66
CLS550
Thank you for the correction. The list is duly updated and your front and rear rotors are now available.
Please note the status:
If no leadtime - In stock ready to ship.
With leadtime - Items are being tooled (order can still be placed)
No live link - Under development.
Old Mar 27, 2013 | 10:36 AM
  #67
AMGDave's Avatar
300D, 500E, E420
Awesome. If you need any assistance with part numbers, dimensions, etc please let me know!
