HELP! Intermittent Shudder Coming from the Rear
The car seemed to have less of these vibrations when I had the trans set to "S" mode instead of "M".
What do you guys think this is? I haven't hit any big potholes or run over anything. Do you think this is a problem with the tranny or diff? I hope not, the car now has 53k on the odometer and there's no extended warranty...
Oops I remember such experience before. Drive it several more days and you will feel the vibration coming from the center of the car. It is not the differential. Your tranmission is shot!
Take it the dealer to check the coolant and transmission oil mixture. I am sure they will have to replace the broken radiator and cooler parts and your tranny. Should get this done in two weeks since they have to ship the new tranny from Germany.Don't worry you are still under warranty, aren't you?
