E39 M5 vs. W208 Clk55
Old Aug 30, 2007 | 09:30 PM
Quant's Avatar
2002 CLK55
how do u guyz think Clk55 would match against the E39 (older ) M5.
the M5 is supposed to have about 400hp and 360tq, but weighs like 600 pounds more than the Clk.
kill stories would be nice
Old Aug 30, 2007 | 09:33 PM
Act of God's Avatar
your mom
I would guess that the ///M5 would have the advantage. There is the power advantage, plus it is a manual. 600lbs is a big difference, however, so that could be somewhat of an equalizer.
If I had to pick, though, I'd say the ///M
Old Aug 30, 2007 | 09:41 PM
DarrenCT's Avatar
i drive an ///M6
close enough where it would be dependent on the driver. given = drivers and conditions, the nod goes to the M5 by about a tenth or 2.......
Old Aug 30, 2007 | 11:16 PM
Quant's Avatar
2002 CLK55
i thought the clk55 had more power because of 376tq
Old Aug 31, 2007 | 09:15 AM
rsr911's Avatar
2003 AMG SL55, 2002 AMG CLK55, 2002 AMG ML55, 2005 ML350, 1995 S320 LWB - totaled
I have driven a DINAN E39 M5 my friend owns. The M5's even stock have major clutch issues and I smoked it with out even trying. So with a little luck you will run up against one of these. Game over CLK 55 WINNER
Old Aug 31, 2007 | 11:03 AM
Chappy's Avatar
AMG
Dragtimes.com has the E39 M5 running all kinds of times - most are within a tenth or two of many W208/55 runs (stock vs. stock).
It would be a driver's race. As Owen mentioned the E39 apparently had a tendency to bog off the line, so unless the owner is willing to sacrifice their clutch, a W208/55 would have a strong chance of winning as long as you could hook up.
Old Aug 31, 2007 | 11:38 AM
RDD's Avatar
RDD
03 M3 coupe 6MT, 05 A6 (wife + kid's)
Yeah, this guy with an E39 M5 wanted to run me one of these days. I said sure knowing he would probably dump his clutch at 4-5k rpm. E39 M5's are fast but they are hard to drive fast by the average driver IMO.
Old Aug 31, 2007 | 12:55 PM
ItalianStallion's Avatar
R35 GT-R, EvoX
I raced my buddy with his e39 m5 with my CLK500 and beat him 7 out of 7 times. Of course, he can't shift for his life and his clutch was on its way out
They're supposed to be pretty fast cars. Would be a great race.
Old Aug 31, 2007 | 01:41 PM
cindyclk's Avatar
Depends on the driver...but here are some sources.
2001 Mercedes-Benz CLK55 AMG 5.0 13.6
2001 BMW M5 4.7 13.2
http://www.albeedigital.com/supercou...0-60times.html
Old Aug 31, 2007 | 04:57 PM
rsr911's Avatar
There you go clutch issues again!
That having been said. YES they are a very fast car. Get one wound up and get it on a fun twisty road, (which is what these cars were built for not drag racing) The M5 is a pleasure to drive. As are our W208 CLK55s.
Old Aug 31, 2007 | 07:34 PM
MidniteBluBenz's Avatar
540 6spd
What do CLK55's trap in q/m? A well driven E39 M5 will trap 108 no problem. I think the gearing of the M5 also comes into play. At lower speeds I'd say it'd be a close race b/w the two cars, but at 100+mph I think the M5 has an advantage.
Old Sep 4, 2007 | 07:25 AM
Chappy's Avatar
AMG
Mine is stock down to the air filters. I've trapped 109.00.
Old Sep 20, 2007 | 08:44 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
not necessarily!
Old Sep 21, 2007 | 09:06 AM
R35 GT-R, EvoX
...wow
Old Sep 21, 2007 | 12:51 PM
Quant's Avatar
2002 CLK55
do u know if ur dyno #s are average
btw, great trap. what the 1/4.
i think someone actually got 12.9 w/ a stock clk55
Old Sep 21, 2007 | 01:13 PM
Chappy's Avatar
AMG
13.349 @ 109.00 with a 2.15 60' Our cars have significant traction issues. BTW, this was with 35psi in the stock tire size (245s in back), 1/2 tank of fuel and a full trunk (no spare, etc. removed). Stock air filters. Had I been 'serious' about the effort, I would have played with the tire pressure and emptied the trunk, but may have only netted another tenth and perhaps one more mph in the trap. I'm 198lb as of this morning.
For a stock W208/55, the best ET I recall was around 13.2X or 13.1X. Check dragtimes.com for more info on that.
As far as "average", I don't know. The other W208 CLK55 tested last fall in Atlanta (same day/same dyno) tested within a couple hp of me. One thing is for sure....W208 CLK55s are under-rated by at least 20 crank hp, according to the pro drag folks I've talked to (based on 1/4 results using weight, ET and trap speed).
Old Sep 22, 2007 | 02:21 AM
ProjectC55's Avatar
Chappy if you did the things you mentioned you could have quite possibly ran high 12's especially with a good 60'. I have no doubt these cars can consistently run 13.0's and 1's to high 12's properly driven.
Old Sep 22, 2007 | 05:58 AM
Chappy's Avatar
AMG
One of the track days in Louisiana next week will be configured for the drags. Since we've got the track to ourselves, I'm hoping to better my previous time.
Old Sep 22, 2007 | 06:11 AM
E55 PWR's Avatar
e55
CLK55 w/ weight reduction mods... forget about it. You can take 150-200lbs out of a CLK easy and that would do wonders. Also you can do crank pulley as well as intake & chip... forget about it. Even modded E39 M5s would have trouble.
Old Oct 10, 2007 | 12:33 AM
ColoCruiserJeff's Avatar
2003 CLK55 AMG
From what I read in Car and Driver (the main reason we purchased my CLK55)
Btwn the BMW, CLK, and the Maserati, the CLK won the battle, with the BMW comming in 2nd
Old Oct 10, 2007 | 01:16 AM
Eurosport's Avatar
monowiper
but in the twisties...
Old Oct 10, 2007 | 01:52 AM
Improviz's Avatar
CLS55 AMG
Naw, not even! E39 was great for such a heavy car, but even with its LSD advantage it didn't turn a quicker 'ring lap than the 208 CLK55...
Old Oct 11, 2007 | 12:17 AM
sd964's Avatar
01 CLK 55
Improviz, didn't you just run against a couple of E39's???
Old Oct 11, 2007 | 02:45 AM
Improviz's Avatar
CLS55 AMG
Yup....there's a thread in this forum w/links to the vids.
Old Oct 4, 2012 | 12:38 AM
Redw20855amg's Avatar
Blown 208 55 amg, 211 55 amg
i got 11.7 but i think my ecu iss tuned idk bought it at auction years ago lol its quite a bit faster than others i've driven..and now its part for a supercharger come to find out my intake mani is ported and polished from hell its like a mirror finish in there ill have to get some pics so i imagine if they went that far its tuned...
My business partner just bought an e39 got it yesterday so we will have plenty of vids only problem is ill be supercharged next time i get the 55 out lol
