WTB.. clk55 w208 intake air box
I haven't seen a dyno on putting the 55 box on the 430, only the individuals own driving opinions. I really would want to see a back to back dyno swapping the boxes right there with like brand filters in place. If anyone actually found any power from it, it would probably be because the 430 has less air demand. I also would not be surprised to see a 430 box actually improve a 55 by at least 5 hp.
This is how my CLK55 looks and it made horsepower.
This is where im gettin my info. You deffinatly seem ta know your stuff. So you would suggest i move away from the 55 or the rentech box? Is that the ML setup mentioned earlier in the pic? The cooler air makes more sence n looks more like what i would want to consider. have you ever done a dyno R/T your intake setup. That info would be real benificial. You may have what we been lookin for.... Look forward to more replies...
I had planned on painting the top of the box black like the car instead of having that cheap plastic look. I think there was also a listing where it could be had for 350.00 it had been posted on the 208 forum.
Greg
The only differences in my current setup is due the fact I have a open element K&N filter, adapter and heat shield. You want sound, this definitely make the engine intake sound.
I am considering the CLK320 factory air box as a next purchase to test. I suspect it's sufficent especially with a K&N filter in it. But that's coming, soon!
BTW, I've never had a problem with K&N's, they are installed in every one of my cars and I've never even had to clean a MAF, let alone replace one of them, be it on my Mercedes or Fords and we put at least 50K. miles on them a year.
There is some differences between the two boxes and there is more filter area on the 55 box as well as the filters being mounted 90 degrees to the others. But 10 hp on a 430, it would have to be because the pinched area at the maf on the 55 box is not restricting the air flow enough to hurt the 430's performance, but it does impede any performance increase on the 55. Both boxes and the renntech box are garbage, all flawed and add NOTHING to performance, they can only rob less than one another. When you try to compare the two engines though, at over 1 liter difference, optimal airflow tuning is a big difference and you need to bear that in mind. My CLK was being hurt by the AMG box, and I could get more out until I found a solution.
Still if I was going to do anything with the 430, it would be what I have on mine, it was dynoed at the AMG event after two others and put down 25-30 hp more than two other clk55's even though I had heavy two piece wheels and the quaife diff. to hurt my figures.
I haven't tested a 430 box or car for that matter, but it would be interesting to study. Maybe you guys can get Da guitarist to come out and play with his. I do have an open mind and a 55 box with brand new K&N's sitting around. We can find a dyno and take both a 430 and 55 and start swapping.
Rich
Rich
Please let me know!! OR we can do it during the AMG meet as well...but I am anxious for the results now
DA Guitarist...I know you are reading this so YOU down with this! My car is perfectly stock down to the filters so this would be a damn good baseline for me as well.
Greg
MBenzman will provide the intakes for me to use on a completely stock 430. We will start the run with a factory 430 air box and then we will go on to the 55 Airbox and then we will use a straight pipe with a filter.
It will be in Marietta, GA at 9 AM if anyone cares to come check it out!! Too early for some beers but we will have coffee available!!
Greg
DYNO Inc.
1535 Rosewood Circle
Marietta, GA 30067
Time: 9 am till ???
And if you are down with 9am beer then hell I am not one to wuss out either so I am down
Greg
The wife doesnt understand my excitement but hell at least you guys do!!
Other than losing the sound from the open element air filter, I feel no reduction in power. I guess the dyno (lie detector) will tell though.
Note, something I hadn't thought of earlier, to install this tube on your cars, which IS obviously what I recommend for a load of reasons, we WILL have to cut your mass air flow connector off and lengthen the wiring harness to relocate it from the back to the side just like I have done. We don't have to shorten it to put it back. If your willing I will bring the nec. supplies, including the proper fabric wiring harness tape to make it appear factory, just like mine.
Let me think about this. LOL
Greg
After seeing your other posts and reading about your majic, you can just consider my car your CANVAS and do whatever it is you need to do for a proper test.
Hell you can have it there all day if you want
I cant wait!!
Greg
Other than lenghtening the MAF wires and extension tube + K&N forward of the MAF, are there any other parts needed to adapt to the intake manifold?
When I replaced my factory MAF I noticed the bracket/90 deg bend that it clips into which leads to the intake manifold, I assume the ML intake slides into this piece?
Also, does the ML intake have the clip provision for retaining the MAF built-in or are other pieces needed?
It is set for 4 more days!! Oh yeah and its the same time and place as well.
Greg
