ESP full-off/open loop on demand?
Old Feb 3, 2008 | 09:39 AM
silence's Avatar
sounds like airplane
I wired in a temporary switch to turn the esp system full-off so that i could easily switch to dyno/race "mode". of course the abs system goes off line as well, but in any situation i should be shutting the esp all the way down i shouldn't need abs anyways (and i'm not likely to forget since it will be flashing all those lights in my face).
i'm planning to make it permanent as soon as i find some aftermarket switches that i like (or some extra benz switches).
I am trying to find a way to literally "switch" the car into full open loop as well. Under cold start the car runs open loop so if i can figure out what sensor the car is using to determine that it is cold- i will be able to wire in a resistor to emulate that and have that be switchable as well. This would allow me to truly "tune" the car using my maf scaler to a higher degree. Anyone know what tells the car it's cold (with this application in mind?)
thanks
Old Feb 3, 2008 | 01:32 PM
juicee63's Avatar
2011 twin turboed prius
thanks
Why not just toggle into dyno mode? A switch is neat butit takes all of 15 seconds to enter dyno mode and shut off ESP, ABS, all electronic interference
Old Feb 3, 2008 | 03:31 PM
silence's Avatar
ah yes- i don't believe my 1999 has that function, but i have read about the newer cars and the way to go into dyno mode. I'm sure there is something similar on mine, but i haven't found it yet (and my dyno guys didn't know it either). I should have posted this in the forum above this one... lol.
anyways-
i've been told (and it seems likely anyways) that the cold start open loop is controlled via a sensor in maf? if that is the case the latter part of what i said above should be fairly reasonable to do.
Old Feb 8, 2013 | 11:00 PM
Redw20855amg's Avatar
Blown 208 55 amg, 211 55 amg
any luck?
